- Feb 3, 2001
I've worked it the trades for 40+ years, everything from automotive to industrial maintenance and all the building trades in between. The knives I used in 40 years the most for work in the order I owned them, why I liked them and why I eventually replaced them. Now I carried an average of no less than four sometimes upwards of a dozen blades at times. Mostly because my job allowed me to and no one looked at me sideways and partly because some of my knives were task specific. Here we go...
My first work knife was a Schrade LB8, mostly because everyone back in the 70s had a Buck 110 a similar and more popular knife and I had to be different.
This knife was used to cut and strip wire, scrape off gaskets and trim gaskets, cut up oakum for pouring lead joints on cast iron drain pipes. Trimming PVC pipe and cutting tie wraps and plastic banding. Most of the work if not scraping and trimming was spent stripping lots of wire.
The clip point blade was great for picking out o-rings and doing the fine cutting needed to make your own gaskets. The belly or curve of the LB8 was great for trimming, scraping and push cutting through cardboard. It's adequate in a pinch for stripping wires and it seemed that I used it a lot for that early on (now I'm smart and have wire strippers). You'd take the wire and lay it on your thumb and roll the blade over the wire taking care not to cut the wire or the pad of your thumb
, bigger wire you would bend in half and as the insulation stretched you'd make light slices across insulation till you hit the wire then you flip it over and do the same to the other side till you can pull off the insulation (this works really well with SJ cord)
The lockback was a feature that was a must have for a work knife that I later learned was totally unnecessary which led to the reason I carried more than one knife. Nonetheless it was the norm in the trades at the time and it made sense to have a locking blade for strength. Logic came into play and that's why I started carrying a fixed blade too.
