I'm under the assumption that people viewing this thread are fairly knowledgeable on sharpening different types of steel and may be able to help me out.
I would consider myself average/capable and consistent in my sharpening abilities. My hand sharpening has gotten pretty decent over the last couple months, and I'm usually very happy with the sharpness of the knives I work on. Having said that, I just got a couple of Boker stockman/traditional style knives. The blades on the one I just tried sharpening were ground very rough and were embarrassingly dull. I went through my usual process (Norton coarse, Norton Fine, Dan's Hard Arkansas, Spyderco UF Ceramic, Stropman Strop with white and green compound). I used a marker to check my angles and raised a burr on both sides of the bevel (a couple of times actually just to be REALLY sure I had apexed the edge). The end result was...disappointing. The edges (3 on a stockman) would barely cut paper (it tore the paper really) and didn't even feel all that great cutting cardboard.
I've had great success on 8Cr13Mov, AUS 8A, VG10, S30V, and different flavors of 1095 (Wife: How many knives does one person need? Me: Um...More?). Arm-hair shaving sharp is my usual standard for those knives, but this Boker steel is somehow different (or at least that's what I'm telling myself). As I'm learning about Bokers, if the blade or handle doesn't specifically state Solingen as its place of manufacture, then the knife is one of their "budget" line, and this knife falls into that "budget" category.
Sorry for the long build up, but here is my question: Are some budget steels just not able to be sharpened as sharp as other moderate or advanced steels? I've read things like, "S30V takes a keener edge then XXX steel." Is this Boker steel just at the opposite end of that spectrum? I don't even know what type of steel it is. How sharp could you get, for example, Buck's 420J steel? Will it shave arm hair? I've seen a guy on youtube sharpen a spoon and shave with it! Shouldn't any steel be able to shave arm hair and cut paper? Or does this knife only get as sharp as it gets and no further? Thoughts? Thanks in advance!
