I use a Lansky system. Would the following make sense? Say the target edge angle is 20 degrees. Use the medium hone on both sides at 20 degrees until a burr forms. Then use the medium hone at 25 degrees using light pressure to remove the burr/wire edge. Then finish the edge with the fine hone at 20 degrees while avoiding bringing the edge to a burr. Finish with strop/steel yada yada...
I think you could do it that way, but with a guided system, you might not necessarily have to. I also used a Lansky a lot, and I developed a habit of using the first hone to create the burr, then using the subsequent hones at progressively lighter pressure to very gently remove it, while 'sneaking up' on the true edge (as you put it, avoiding bringing it to a burr again). I didn't elevate the angle at all, but made sure to very closely examine the edge under magnification & bright light, to see my progress. By the time I'd reached the fine hone (purple ceramic in the blue holder), virtually all of the wire edge was gone. I'd use the fine and UF (white in yellow holder) to polish & refine the bevel. So long as the finishing stages are done at very, very light pressure, the wire edge/burr can be very gently filed away at the same set angle. A guided system makes this much easier, and produces an excellent result if done very, very gently.
When I'm just trying to remove the burr from an existing (factory) edge, and I'm doing it free-hand, I do find it simpler to do it at a slightly elevated angle, with the wire edge curled down into the hone. This method is geared more towards breaking the burr/wire off, by bending it back & forth, as opposed to filing it away.
This is definitely something I confront with more stainless blades and not with carbon steels as much.
Exactly. I think the extra chromium in stainless alloys is the biggest contributor to the added ductility, which is what makes the wires/burrs much more 'bendy' (without breaking off as easily). That ductility can be offset somewhat by heat treat to a slightly higher RC. The best example of that is comparing Case's Tru-Sharp (which is actually 420HC) to Buck's 420HC. Buck treats their blades to an additional 2 or 3 points on the RC scale, and I don't see the same stubborn wire edges on those blades (wires/burrs break off a bit more easily). Additionally, most of the popular carbon steels, like 1095 and CV, have a higher carbon content (above 0.80% carbon) than a lot of the common 'high carbon' stainless steels (around 0.50% carbon), which acts to make the steel less ductile (slightly more brittle), which therefore reduces the wire edge issues.
