- Oct 25, 2005
Ok, I'm a bit of a newbie. What exactly is G10 and what makes it superior to micarta?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
It's a fancy way to say fiberglass.
G10 is simply fiberglass, as most folks use the term. That is, fiberglass in a thermosetting plastic. A fancy version of the same stuff used to fabricate giant figurines and kit car bodies. Any non knife nut will certainly see the similarity. My definition still stands.
AFAIK, FRN is just a fancy way to say molded plastic. Whether it has fiberglass, or pink glitter mixed in, it's still thermoformed plastic. Generally pretty easy to distinguish from G10. I doubt anybody would colloquially call FRN fiberglass.
Is all G10 in the knife industry the same? For instance, G10 on Cold Steel knives vs. G10 on Spydercos?
Not true.Comparing G-10 to Fiberglass is like comparing standard Aluminum to 6061. One is soft like lead the other is a pretty tough alloy. Fiberglass is brittle, flaky, and will begin deteriorating in the elements quickly (rub your hands on a sheet of fiberglass that has set outside for a year. It's like chock.) G-10 will hold up to a lot more and costs more to produce. And is pressed and backed. Hence why you don't see G-10 boats.
G10 is made with fiberglass. In the same way micarta is made with linen paper or canvas.
Yes, G10 is made from fiberglass, but it is not correct to say that G10 is merely fiberglass.
