Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I etch damasteel at room temp. Usually around 80°F. Never had an issue.
When etching, acid volume is important … you need enough to have plenty of fresh ions.
Also, take the blades out every so often and rinse them down well, brush them off with a wire brush, rinse again, and put back in.
Caution Note:
For those not familiar with using acid to etch it is not a process for most hobbyists. It takes a proper location (NOT the garage), safety gear, knowledge, ventilation, and equipment. Muriatic acid is hydrochloric acid and is nothing to play with.
Caution Note:
