- May 23, 2007
I am setting up my KMG for variable speed and I picked up a new Leeson 1.5 hp 3ph motor on eBay for dirt cheap. Only problem is that the shaft has no keyway. It is a pump motor with a 5/8" shaft that is threaded on the end. I'm trying to figure out the best way to mount a pulley on the motor. Here are the option I'm considering.
1) Use a fixed bore pulley. Drill a dimple in the shaft and just use the set screw.
2) See if a a motor or machine shop can mill a keyway in the shaft.
3) Use a pulley that uses a tapered bushing to mount to the shaft. I was looking at the QD and split taper bushings and pulleys. They clamp to the shaft and also use a key. I am just not sure if if the bushing will clamp to the shaft tight enough by itself (no key) so it won't spin.
4)Use a keyless bushing like a Trantorque. These don't need a key but I can't seem to find a pulley to use with it. I'm not sure if a regular pulley(with a keyway and set screw) will work.
Any ideas what would work best?
BTW, when in looking into the Leeson motor I found out that all of their 3 phase motors over 1 hp are inverter rated.
Thanks!
Lon
Thanks!
Lon
