Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I have recently had a lot of steel type questions, and some queries about this steel vs that steel.
I won't go into which stainless is best for what purpose, but the question of 1084 vs 1095 is a good one to post some info on.
Replies to this thread should be from personal experience with it, or questions and comments about specific attributes and requirements of these two steels. Lets not get too far afield into discussing other steels, as that will quickly become a quagmire.
Here is a recent response I sent a forumite on this question:
1095 and 1084 sound like the the only main difference is .11% of carbon. But
there is more than that to it.
1095 is a shallow hardening steel, with somewhere between .90 and 1.00%
carbon, .30% manganese, and not much else beyond traces of this and that.
W-1 and W-2 are similar steels to 1095.
These shallow hardening steels are trickier to get a perfect HT on, and
require a very fast quenchant.
1084 is the eutectoid steel, and has between .80 and .90% carbon, .90%
manganese, and traces of this and that.
The added manganese makes it deeper hardening, and being the eutectoid, a
soak is not needed in HT. Any reasonably quick quenchant should work. Canola
oil is fine for 1084.
Aldo adds a little vanadium to his 1084 as a grain refiner, and it is
usually about .89% carbon......so it is close to 1095 in carbon content, but
easier to HT.
OK, now as to telling them apart once the knife is made and hardened.....you
probably can't. They should cut and last close to the same. A metallurgical
laboratory making and testing 100 knives of each steel might get an average of 2-3% better
edge retention results for the 1095, but the normal knifemaker may gain or loose that
much in just HT error.
Basically, if two identical 1084 and 1095 blades were made, and both had
perfect HTs, and both were tempered to Rc59 - you could not determine which
was which without an analysis.
So, why use 1095 or W-2 if it is harder to HT and gives the same blade?
It is because of the shallow hardening. That allows differential hardening
and the attaining of a hamon or quench line. This doesn't make any
difference in how the knife cuts, but can make it beautiful. It also proves
the smith knows how to do the complex HT to attain it. It can be compared to
fancy engraving on a old handgun or rifle. It doesn't make the gun shoot any
better, but proves the quality and skills of the gunsmith who made it. These
are aesthetic items, but add a lot of value to the knife or gun.
Beyond the desire to make a blade with a hamon, or making springs, there is
no reason that 1095 would be preferred to 1084 in function.....and the 1084
will likely produce more consistent HT results. Since Aldo has introduced
his improved 1084, many smiths use it as their stock steel. There
is a lot of wisdom in using only one steel for all your carbon steel knives.
I pretty much use Aldo's 1084 for all my carbon knives, and
CPM-S35VN for stainless blades. The exceptions are swords from 1070, hamon
blades from W-2, and super stainless blades from exotic alloys like Cowry-X
and S90V.
1084 also will make a better damascus mix than 1095. The deeper hardening
1084 matches the properties of 15N20 very well., and shows a great contrast.
Hope this helps.
easier to HT.
and S90V.
Hope this helps.
