What is your experience with Spyderco factory edges?
Discussion in 'Spyderco' started by retzius, Oct 18, 2017.
  1. retzius
    retzius
    Sep 17, 2009
    Hello everyone.
    I can only speak to the Spyderco knives that I have purchased, but I have had enough samples go through my hands that I can make some generalizations.
    The good: All of my samples have been very sharp and have been sharpened all the way to the apex. I have never had a sample that would not cleanly cut paper.
    The bad: Although my samples have all been "sharp", they have all been inconsistent with one side more obtuse than the other. This may just be an indicator of the "handedness" of the individual sharpener, but I notice that one side is usually around 13-15 degrees and the other around 18-20 degrees. Its not an issue until you decide to sharpen the knife on the Sharpmaker and you recognize that you are hitting the apex on one side and the shoulder on the other. Most of us on BF have the experience and forethought to knock back the shoulder on the obtuse side and then sharpen the blade but for the mass market consumer this could result in the often heard complaint, "I can't get my knife sharp", because they aren't hitting the apex on one side.
    The ugly: I have had at least 5 samples where the edge veers off to one side progressing from heel to tip. This is much more difficult to correct during resharpening, especially when combined with uneven edge bevels and the propensity to use super-steels. This is further compounded by the lack of sharpening choils on most of Spyderco's knives.
    So what are your thoughts?
    We are much more critical than the average consumer and for the price point of many of Spyderco's more popular knives a "sharp" edge may be adequate.
    When does the price get to the point that a better edge is expected?
    Have a good day!
  2. Danke42
    Danke42
    Feb 10, 2015
    Never had a problem and never had an issue maintaining one on a sharpmaker. That's looking at 22 different variants from the US, Japan, and Taiwan production.
    115Italian likes this.
  3. GB940Rookie
    GB940Rookie Gold Member Gold Member
    Apr 19, 2016
    I never expect A knife to have a good edge when I get it so that way I'm never disappointed.
    In my experience Spyderco has always delivered acceptable edges. Cold Steel and ESEE have the most consistent per my experience.
  4. Mo2
    Mo2
    Apr 8, 2016
    Spyderco has been the most consistent in great edges for me over any other brand.
    abbazaba likes this.
  5. Seneca18
    Seneca18
    Jan 2, 2015
    I've never had an issue with an edge on my Spydercos until I go the new Opus. That thing was just way off, uneven grind and dull, but I guess 1 out of 190 or so Spyderco's I own isn't bad at all.
  6. 91bravo
    91bravo Gold Member Gold Member
    Jun 29, 2008
    The Spydies that I have bought in the last year or so have been great, some better than others. Few years back, some of the grinds were like the OP's. The primary grind was off a degree or two, which in turn, makes one side of your edge look wider than the other, although they are both sharpened at the same angle. I even got a few where there was at least an 1/8" of unsharpened edge near the ricasso and then a slight recurve, when it should have been flat. I believe that Spyderco automates their sharpening process now. I know years back, it was done by hand, which introduces the human element and won't be as consistent as machines. That being said, most of Spydies have come with at least a good working edge, some better than others!
    MarriedTheMedic and skwurll like this.
  7. SV-97
    SV-97
    634
    Aug 18, 2016
    Never had a problem(across the board 25 knives, 19 models) except for the mantra 2 which had 27dps and horrible uneveness; but even that was quickly fixed on the wicked edge so no problem for me. I really couldn't care much less about factory edges
  8. halden.doerge
    halden.doerge I'll Sharpen Your Knife Gold Member
    Aug 17, 2014
    I would say that Spyderco has the most consistently best factory edges overall, from a production company. Although, honestly, Benchmade is right on their heels in the sharpening department in my experience.
  9. mael333ca
    mael333ca
    447
    Jul 5, 2012
    factory edge are not usually awesome, with a little bit of patience and skill over time, its easy to put by hand a finer edge, and its supposed to be always good to removed the surface metal by hand that was grinded off by machine.
  10. jbmonkey
    jbmonkey Platinum Member Platinum Member
    Jun 9, 2011
    not for me. benchmade has the worst for consistency and obtuse angles and offset from each other. im comparing ones ive bought over the last 10 years. they have gotten much better lately though. cold steel is very consistent on the pricer knives not the cheap machetes and such. buck does a darn good job of consistent. spyderco american made ive had good luck. many japan ones very obtuse and wildly different angles. not all though. some taiwan ones slightly obtuse and differing angles....consistently better than the japan ones. thats been my experiences on literally hundreds of folders and fixed over a decade plus and then some. many brands i left off...too many to list.
  11. halden.doerge
    Aug 17, 2014
    As always, mileage may vary.
    jbmonkey likes this.
  12. skwurll
    skwurll
    Oct 12, 2008
    Spyderco's edges have improved a lot in the last 5 yrs. Recently everything I've received has been even and well done. Some of these steels aren't easy to work with & they're sharpening thousands. They probably have huddle prior to a Maxamet batch.:p
  13. Officer's Match
    Officer's Match Gold Member Gold Member
    Jan 23, 2013
    My KW 204P Military came with one of the very best edges I've ever had out of the box, dead symmetrical and very sharp.
  14. Mo2
    Mo2
    Apr 8, 2016
    I haven't got a benchmade with even bevels. And often get burnt edges. It's horrific and this is what most people see. Just saying. I know you've had great luck and that's awesome.
  15. halden.doerge
    Aug 17, 2014
    Yeah, I don't think either of us can authoritatively say what "most people" see. Probably should stick to just what we see. And of course mileage will vary.
    I'm way into sharpening. Nearly all the knives I get go on the Wicked Edge and get a screaming high polished finish they day I get them. CRK, Hinderer, Strider, ZT, Viper, Lionsteel, etc, all of these that I've owned have gone straight to the sharpener, out of the box. The only knives I seem to ever find myself waiting to sharpen are Benchmades and Spydercos (and, as someone mentioned above, most notably the USA made Spydercos).
    Have I gotten examples from both of these with uneven bevels or edges that didn't satisfy me? Of course. But out of all of the above, these were really the only ones that would at least sometimes get it right.
  16. yablanowitz
    yablanowitz
    Apr 14, 2006
    I don't think I have ever been satisfied with a factory edge on any knife I've ever purchased (and that is well over a thousand). I generally put my own edge on a new knife before I use it anyway. Factory edges are for people who can't sharpen a knife.
  17. Wowbagger
    Wowbagger
    Sep 20, 2015
    Totally
    The Taiwan edges have been the best . . . no complaints about the Japanese edges. . . really nice . . . the Golden, CO edges . . . wellll . . . I guess they cut stuff sort of . . . most of the time. The worst edge bar none has been the one on my Manix LW S110V and the one on my Para 2 S110V was right about the same = piss poor; barely sharp (not the least bit shave sharp); rough and to use a technical sharpening expert term . . . funky.
    My UKPK in S110V was actually pretty darn nice and useable out of the box just a touch with an 8,000 diamond stone and it was shaving nice. (I forget where those are made).
    Bottom line : white guys can't jump (or sharpen knives) :) :eek: :)
  18. ScooterG
    ScooterG You mean Ireland? Yeah, it’s mine. Platinum Member
    Mar 15, 2016
    My rankings below:
    1. Stupid Sharp
    2. Excellent
    3. Really good
    4. Good
    5. Not so good
    PM2: I’ve had good (M390) to excellent (CF M4) to stupid sharp (Cruwear Sprint)
    Para3: Excellent (Cruwear)
    Manix: Really good (Cruwear exc, S90V exc) to stupid sharp (Maxamet)
    Military: Excellent (Cruwear, S90V, M4, S110V)
    Yojimbo: Excellent (S90V)
    Lil’ Nilakka: Stupid sharp
    K10: Really good, but held the edge
    Southard: Not so good
    GB1: Excellent
    Native 5: Good (S90V) to excellent (Maxamet)
    DF2: Good (ZDP189)
    I can go on and on, but overall, really good-excellent. The thing is though, that some of those Excellent to Stupid Sharp edges didn’t always hold very long or as long I thought they would. Also, I think Spyderco pays a bit more attention or puts the A-Team on the sharpening belt for Sprints/Exclusives.
    halden.doerge likes this.
  19. anycal
    anycal
    463
    Jan 11, 2017
    Most of my Spydies are Golden made, and they all came in sharp and without major issues. Para 3 CRUWEAR came in the sharpest. Out of my 4 Japanese models, only one was relatively dull. No Taichung yet.
    I too like to hit up the edge pretty early on. I have an Edge Pro and also do pretty good free-handing, so I don't have a problem even if something doesn't come in flawless out of the box.
  20. 017
    017
    202
    Mar 31, 2016
Share This Page
