Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Google Nimrod pipe lighters and look at the images.
Butane burns too hot so you really shouldn't use it for pipes.I use regular Bic's or matches. I use up the butane too quickly in the nice pipe lighters and I'm always afraid of loosing one.
As Jacknife says....
Years ago, during my rather brief excursion into pipe smoking, I read up on the subject; the history and practice. That anyone would use a petro-fueled Zippo to light the pipe would have caused all the VERY serious pipe aficionados to simply faint dead away.
Almost as bad as drinking beer from the bottle....
The wooden match is the preferred instrument, you see, and ONLY after letting the head combust sufficiently so that there is no trace of chemical taint.
The dedicated butane pipe lighter is considered marginally acceptable, but likely frowned upon.
Then there is the method... After properly tamping the pipe full of tobacco, in thirds, so that it's not-too-tight and not-too-loose, then one applies the flame sufficient to start the top layer. This will cause that top layer to expand from the heat.
So...One then re-tamps the tobacco, and re-applies the heat source.
Done properly, this will result in a good draw that's not too hot and will sustain combustion... Though one may have to re-tamp halfway through the bowl.
Some cuts of tobacco burn better than others, and of course tobacco that's been allowed to dry out too much will burn too fast... Thus the reason for the humidor.
Finally, if smoking briar, one must "rest" the pipe after a day's smoking, which is why most briar fans have lots of them.
This need not be done for the meerschaum pipes, or the calabash. (though the calabash must be cleaned periodically).
Sucks carrying matches everywhere you go especially in summer without coat pockets. Also sucks if you need to relight in a car.Lighters are a means of absolutely last resort for lighting a pipe.
First choice is old fashioned wooden matches.
I've smoked pipes for a couple of decades now, and that just ain't the case. At least it is certainly overstating it greatly. That's why you could, and can, buy Zippos and Zippo fluid in even the finest tobak shops.Years ago, during my rather brief excursion into pipe smoking, I read up on the subject; the history and practice. That anyone would use a petro-fueled Zippo to light the pipe would have caused all the VERY serious pipe aficionados to simply faint dead away.
That's called the false light.Then there is the method... After properly tamping the pipe full of tobacco, in thirds, so that it's not-too-tight and not-too-loose, then one applies the flame sufficient to start the top layer. This will cause that top layer to expand from the heat.
A single box of small wood matches gets lost in jeans pocket or cargo shorts.
