I've decided to take advantage of the fact that my Rossi .22lr/20ga "Matched Pair" single shot has a hollow in the buttstock. For those not familiar with it, the entire butt is not hollow. There is a drilled out cylinder the same diameter as a 20ga shell running almost the entire length of the butt. I'm assuming they did this to reduce weight. I've since learned that this a common method of stock attachment. I knew the bolt was at the base, and its purpose, but was not aware if it was common or not.
I'm trying to decide what to include in this space. It would hold 2, possibly 3 2.75 shells. It could also hold approximately 40 .22lr. instead. Probably more if I was really careful packing them in.
My current plan is to carry 1 20ga shell of #3 Buck, 10 .22lr CCI SGB, and filling the remaining space with fire starting and cordage materials. Should I just load up with ammo instead? Would it be easier to just carry ammo in the "Matched Pair" carrying bag? I've decided against cleaning supplies because this is such a simple firearm that cleaning it can be improvised with almost anything. Should I use all the space for gear instead of ammo?
None of the gear in the butt would be my primary. It would be secondary, and in most cases, tertiary gear.
I'm hoping to not only get some good ideas but to stimulate an interesting discussion regarding pro-cons, weight, ammo selection, gear, etc. etc. Thanks in advance.
Edit: One thing I forgot to add is that right now I am leaning against a butt-cuff style shell holder. The stock is very slim and none of the couple I have laying around would stay nearly snug enough. It would also make it more difficult to store the stock/receiver in the carry bag. Not to mention that I would have to customize one to carry both .22lr and 20 gauge or the holder would not be worthwhile half the time.
