Originally posted by .45acp
I do not have any personal experience with the stabilized woods, but there are many good things written about them.
Here's my reasoning (read "guess") on why I brought up
Stabilized woods -
and why I suspect they may be as strong and durable as Micarta class materials.
Micarta is basically epoxy impregnated cloth or paper - can be thought of as epoxy strengthened by cloth or paper, or obviously laminates of cloth/paper bonded by epoxy - once explained one can see this sounds strong.
Using wood laminates in a similar manner would/should give about the same strength and durability hence cpirtle's take that "diamondwood" should be about the same as Micarta (as would the similar PakkaWood).
Stabilized woods are different in that the whole wood is used - and often it is a weaker or more fragile wood like spalted woods and burls. But these are infused/impregnated with epoxy/polymers under vacuum pressure so that every pore/grain of the wood is infused.
So basically this is wood with all of its pores, grain, gaps filled with epoxy -
think of it as wood with its structure filled with epoxy,
or even epoxy strengthened with a wood skeleton/structure.......
Sounds pretty strong and durable to me -
but then I am not an authority on this -
have done no measurements/tests
and the samples of stabilized wood I have are all on knife handles
and are way too pretty for me to want to "test" to destruction.
I would love to hear of any tests of the strength durability of stabilized woods.
For example could stabilized woods using spalted, burls and even soft woods which are normally considered weaker woods actually be
stronger due to the fact there would be more epoxy in the wood faults/gaps? Whereas a closer grained hardwood, although stronger in its natural state, would actually absorb less epoxy?
I find the beauty of stabilized woods is that one can now get really stunning examples of wood that would be normally regarded as too weak and unsuitable now on handles and because they are stabilized they could be as strong and durable as a man-made material like Micarta....
sounds pretty cool to me
