- Nov 3, 2008
Hi folks , I've recently started making slipjoints with traditional construction methods , but have recently run into problems with pivots !:grumpy: I am doing a small batch of swayback Jacks that have stainless bolsters and I have used a stainless pivot and peened /domed it before sanding flush for an invisible look . But my problem is this , after a few dozen openings the spring is no longer flush in 3 positions and the action gets stiff and feels like it is galling. On removal ( drilling out and much swearing ) of the pin , it is evident that the pivot is too soft and the blade has worn it . . . .
What grade of stainless should I use ? I can heat treat carbon steels but do not have the ability to harden / temper stainless , so I am looking for a grade that I can machine to size and peen but is hard enough to last in it's SUPPLIED state . . . . My folders up until this point have a nice smooth walk and talk and are not nail breakers , the spring is not preloaded hugely . . . The blades are 01 steel rockwell 58/59 with drilled and reamed holes and I machine the pivots from 303 bar stock on my lathe to close tolerances
I have noticed on some of my production knives it seems they use brass or nickel silver ! How is this possible ?
So come on guys , what do you guys use and where do you get it ? Thanks in advance
