from what I know, the steels that make for the sharpest edges aren't used for the sort of knives you'r talking about. japanese carbon steels like white #1 (shirogami) and blue #2 (aogami). also blue #1 (rarer). those are often considered better then VG10 (for example). but those are used by japanese knife makers, and they are mostly used for japanese style knives - mostly kitchen knives.
there's O3 tool steel that I understand is similar to blue #2, might be more common in use for knife making.
there's the hi-tech powdered steels - all sort of stainless supersteels, but I hear they are a bugger to sharpen and cost too much in
Murray Carter uses those steels(at least some) in his neck knives if you must absolutely have those.
I don't spend that much money on my non-cooking related knives...
Steel type has nothing to do with sharpness. You can get Mild steel just as sharp as ZDP or S30V.
Edge retention has to do with Steel type (and cutting edge geometry, heat treatment etc).
You're asking the wrong question.
Edit: well, almost nothing to do with sharpness. In general steel types with less carbides can attain a sharper edge than steels with large amounts of larger carbides. But in general you won't really notice the differene unless you attain a serious microscope.
Right now I'm under the impression that ZDP 189 is. It's brittle so people sandwich is w/ 440C.
The sharpest steel is the steel sharpened by the most skilled sharpener...
Not quite.
For any steel or alloy that a reputable knife maker would suggest for a blade, your statements would be somewhat accurate. However there are numerous offerings that are touted as straight razors that prove your statements to be completely wrong. If you like, I can point you to some resources where world renowned hone-meisters (a term reserved for HIGHLY skilled razor honers) have taken the challenge to make some of these blades shave ready (i.e. suitably sharp for shaving) and they cannot accomplish the task.
