chrome ox graded at 0.5 microns is extremely closely graded and also slow for anything with complex large carbides or high hardness. I'd strop 3v with 1/2 or 1 micron loose diamonds (you can buy them on ebay for about a quarter a carat last time I checked). Every loose diamond vial, bag or whatever else that I've ever purchased has been very closely graded. I'd save the chrome ox for straight razors.
I've always avoided the sprays because it's just as easy to sprinkle a bit of loose dry diamond on something and then add a drop of mineral oil to move it around, and you can have 10 lifetimes of diamond doing that for $25. Not much issue with contamination as long as you don't use larger diamonds (anything loose-sprays, powders, whatever, will end up somewhere else sooner or later either on your fingers or on a blade. If it's super fine, contamination doesn't matter).
A hard buff (powered) with aluminum oxide would probably be faster and more effective than a strop with diamonds even though it may not be optimal for the carbides. you can use the corners of a buffing wheel like a hand strop - the face of the buff will round over an apex some, but the corner doesn't have enough backbone to do much and the buffer is better at completing the job than we generally can do by hand.
(sub micron diamond buffing compound could be made pretty easily for a buffer with gulf wax and loose diamonds, too).
