- Jun 8, 2000
So I bought a couple fire bricks today and a propane torch and a hard drive magnet and am hoping to try to heat treat a small knife I've ground out of some 01 stock. I'm going to drill the fire brick as indicated in the How to heat treat 01 thread and build a one brick forge. My question is what to hold the quenching oil in and how much oil do I need. I grabbed a gallon of veggie oil at the supermarket, but it looks like I might need more? Should I just buy a cheap stock pot and put a couple gallons of veggie oil in it? At first I was thinking that I'd just cut the top off of the veggie oil container, but then I figured that if I touched it with the hot steel, I could end up with oil everywhere, and that would suck.
Some guys have mentioned heating the oil. I was thinking that I could put it on my gas grille on low to heat the oil and set up the one brick forge near by on an old washing machine basket.
Once I heat to non magnetic and quench the blade, what's a good temper recipe to draw the 01 back down?
Can I use channel lock pliers to work with the hot blade, or is something else recommended?
They seem like dumb questions, but I don't want to screw this up.
John
John
