What tool for removing Spyderco belt clip?
I have a Spyderco Tenacious and wish to move the clip to the other end of the knife. I thought I had a fairly good collection of both Allen and Torx wrenches, but nothing that I have will fit the tiny screws holding the clip to the grip. Since I can't see the screw's head too well, I'm not even sure if I need an Allen or Torx wrench.
Can someone tell me what type and size wrench I will need to remove the 3 clip screws? Thanks in advance!
i use a husky torx driver with four double sided bits that i got in homedepot for $6.
http://www.homedepot.com/catalog/productImages/300/0c/0cc66c97-59bd-467d-9c41-48fff3c20a49_300.jpg[IMG][/QUOTE]
This is what I use. It's very simple and great to have around.
1.5 mm hex
The 1.5 mm hex turned out to be too small for the screws on my Tenacious. I picked up an SAE screwdriver set, #97517 at Harbor Freight, and found that the 1/16" hex fit perfectly.
The 1.5 mm hex turned out to be too small for the screws on my Tenacious. I picked up an SAE screwdriver set, #97517, and found that the 1/16" hex fit perfectly.
LMAO, I have that one too ! If you own Gerber knives, then you KNOW that they are notorious for loose handle screws. Thats why i got those sets. You need one on each side for some of them, to hold one side while you tighten the other. Glad to help.
