As an example of use, A2, D2 and M2 are all used in planer blades.
In short, tighter tolerances on composition.
-Cliff
I'm sure what you mean by "tighter tolerances" of composition. A crappy D2 is imo still a D2 and not for instance a martensitic chromium steel. I dont think you are right here Cliff.
It
has to do with composition and the application. The boundaries of steel classes are a bit fluid but I'll try to explain.
* Carbon steels - these are pure iron and carbon compositions (I chose to disregard impurities). Ex C75, 15LM.
Band saw steels are here.
* Low alloyed steels - basically carbon steels with a number of alloys but basically non of them are more than 2-4%. Sometimes reffered to as tough-hardened steels. Also non-stainless. Ex
D6A steel.
* Martensitic chromium steels - Iron, carbon and chromium (ex. 13C26)
* Austenitic steels - classical stainless steels. Iron, carbon, chromium and nickel. 18-8 steel is here. 18%Cr and 8% Ni, this came with the invention of the dishwasher. Big application is cutlery like spoons, forks etc. It's expensive now with nickel prices so cutlery now tends to move to martensitic chromium steels.
* There are several others like, precipitation hardening steels, Ni-base, Cobalt-chromium etc. but I'm not writing a report here.
* So then, finally we have
Tool steels. There are 4 fundamental types:
1:
Carbon steels - High carbon steels. 1% and up.
2:
Hot working tool steels - Used for heat/wear demanding applications such as tube extrusion. They have Cr <18%, Mo <2%, Ni and Tungsten.
3:
Cold working tool steels- <18% Cr, <5% Mo, <2% V. Used for wear demanding applications like blanking.
D2 and A2 are cold working tool steels.
4:
HSS - High speed steels - <4% Cr, 4-10% Mo, <2% V and <20% Tungsten. These are used for milling, turning, drilling and such metal working applications.
The M-series is here, like the M2.
Imho, none of these tool steels are very good knife steels because of the mega-carbides you get from the combination of high carbon and high Cr/Mo/V etc. I believe the martensitic chromium steels with balances compositions are better suited as knife steels.
//Jay
PS. I sometimes write a lot about swedish steel makers and especially Sandvik. that is because they are located only a few miles from my house and the pre-dominant employer in the area. So here is another Sandvik fact, they produce around 900 grades of steel. A big portion of this about 50% I've heard are own developed patents.
