- May 19, 2002
I need your help. I am getting ready to buy or build a forge. I cannot decide if I should go with coal or gas. I can weld and use a cutting torch pretty well. I work for the gas company as a serviceman, so I have a pretty good understanding of gas use, pressures and so on. I will use the forge for blades and small blacksmith work. I would like to keep the cost to around $200.00 if I can. I really like a coal forge as it is quiet and comes up to heat really fast. I have a good source for coal about 2 hours away, so that is no problem. I have read that the pan or brakedrum forge is really hard to control the fire if you are not experienced. Could I put a hand crank on a squirrel cage fan and reduce it down for a blower? The main disatvantage I can see is building a hood and flu for the coal smoke. As for gas, I have not seen one in use, but I hear they are very noisy, take a while to come up to heat and do not get as hot as coal. Do I need a hood and flu for gas fumes? Please share some ideas to help me decide which way to go. Thanks
