I want to check my two Paragon's to see if they are accurate. I have heard of using ceramic cones that melt at a certain temperature. I have heard of using salt, I have heard of something called temperature sticks.
What would you suggest?
I have two lab testing units that has three independent PIDs in it to check temperatures and calibrate TCs. Looks like something out of the space shuttle. I bought them surplus for $10 each. Probably cost $1000 each new.
A good way to check a TC is to place in a pot of boiling water ( not touching the bottom or sides) and read the temperature. Check the boiling point for your altitude first*. Check the reading to two decimal points if the unit allows, as the accuracy must be very close at boiling. Error is usually linear. That means a 1° error at 212° could be a 10° error at 2100°.
I have used my five probe unit for simple readings to compare areas on a grill, check for hot spots on a machine, etc. I haven't used it for checking a kiln because I had better choices, but it is worth a try. At worst, you will have a $20 so-so thermometer that is good for checking the quench tank, and three spare TCs for the kiln.
