Alex Topfer
Basic Member
- May 1, 2019
Well damn, that looks like terrible grain
Grinding 15v, Maxamet and Rex121.
Almost out of belts
About 6, 60grit Ceramic belts for the rex 121 at 70rc so farHow many belts do you go through on one of those knives? Sounds like you need to get a connection for CBN belts and start your own BBB line of belts lol.
Almost out of belts
WHAT speed /SFPM/ you use for grinding this thing ?Grinding 15v, Maxamet and Rex121.
Almost out of belts
You can not grind steel with diamond belts .Next time read all details ....What brand of belts are you using? With how expensive that sounds, you may consider diamond belts with wet grinding at slower speed to protect the diamond from breaking down.
https://www.3m.com/3M/en_US/company...reselect=8763352+3293190396+3294857497&rt=rud
Maybe something like that and use a belt splitter on it since it's 4 inches wide. Never tried it myself but it may be worth trying for you considering the expense of that many ceramic belts per knife.
What he need is CBN belts ..............and he know that We wait price to go down..........littleCarbide, Cast Iron, Ceramic, Chilled Cast Iron, Chrome Carbide, Chrome Oxide, Granite, High Nickel Alloy, HVOF, Nickel Based, Non-ferrous Metals, Oxides, Soft Metals, Stone, Tungsten Carbide
I have a 1.5hp 2x72, the motor doesn't have crazy SFPM. I'm using 40% to 20% speed on the VFD dial as needed. I found going at 70% -90% is not as good as going slower and putting your body weight into it.WHAT speed /SFPM/ you use for grinding this thing ?
You fracture grains to fast on slow speed with that kind of pressure , that s why you use 6 belts on one knife . I grind them most time on 40m/s with ....well how I would explain what is medium pressure by my standards ????? Look , if you feels that more heat is produced than it needs in most case low pressure on steel is applied .Don t give up from speed ,with test you can find right speed and right pressure . That finish is very , very rough , try at least when you are close to finish with grinding to speed up on max .grinder and make several light pass........it's not fun at all to hand sand steel like thatI have a 1.5hp 2x72, the motor doesn't have crazy SFPM. I'm using 40% to 20% speed on the VFD dial as needed. I found going at 70% -90% is not as good as going slower and putting your body weight into it.
Fast speed just sheers off all the sharp grains and makes far too much heat if adding the pressure needed to get these belts to remove steel.
20 m/s would work fine with right pressure ...........
