- Feb 10, 2021
Years ago , I believe that I spend more time to learn how to post picture then to make knife .Let see how you will handle that
Posted above!!
The
The tip isn't burnt. Just a funny shadow.
The
Digging that one man! Super cool!I'm working on about 50 right now... had a bandsaw and compressor down so now I'm finishing a lot. Here's a Beta Ti Kwaiken close to completion.
Like it ! But , start hand sanding from plunge line towards the tip , not from flat part of tang .The
Looking good man. Great first choice for a knife design.
Little bit more time with some vertical pulls the full. Length of the knife will help clean up the finish a lot.
Watch the Nick Wheeler hand sanding YouTube video if you haven't already.Thank you!! I'm doing it all by hand, so it's taking time, LOL.
If you go through the grits too quickly, then you have a polished surface that you are reluctant to spoil, but upon changing directions and close inspection under light or a photo, you will see residual scratches.
It is much faster to drop down and get a truly smooth surface to a lower grit and then come back up, than to stubbornly continue with the higher grit.
I have the Rhynowet red paper. I will often start at 120 grit and go until there are no other scratches. I use a hard backing and clamp my piece along a board.
This part takes the longest thanks to my love of 36 grit belts.
Going to 180, 320, 600 and beyond is relatively quick after that.
That happened to me once... and I just re profiled the edge to have more curvature towards the handle,creating a continuous curve. I think Stacy has said he does the same thing?
Leave it as-is, and you'll have a pretty decent first knife. Clean up the finish, and you'll have a really good-looking first knife.Quick question. Now that I watched the video and am learning how it should be done (not the way I did it, LOL), would you suggest I go back to a lower grit and do the one pass at a time technique? The grit it's at right now is 600. I almost feel like I should go back to 320 to fix it. Thoughts?
