Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
If you consider price, AEB-L is pretty good quality with pretty low price. If the price is not so important, then there are much more better steel than AEB-L. My favourite is aogami super (commercial steel), customs - hard-matrix wootz. These 2 steel requires some experience in sharpening, as the hardness is over 65 HRC.
Everything is a trade off. For prioritizing fine edge stability, aeb-l, 52100, W2, and hitachi White are considered the top steels. W1 and 1095 are in this group as well. If you want to prioritize edge holding, there are many great steels. I’m a big fan of z-wear now, but there are numerous similar steels that take a very fine edge, maybe a step down from the first group I listed, and hold that edge a long time. Hitachi Blue, z-wear, many German tungsten based alloys, cruforge-v, S35VN etc. are all great choices. Getting a higher wear steel than z-wear or S35VN brings you into higher alloy steels that tend to have slightly toothier edges, but will still get crazy sharp with good sharpening equipment and technique.
The previous answers are all relevant as generic answers, but I'm going to make some assumptions about what you might find "best". And make a recommendation that's sure to get someone's hackles raised.What is the best steel to use for a chefs knife.
Im making my own knives.
I was concedering using AEB-L stainless steel.
Any opinions.
Warren, 1.2442/115W8 also has some pretty darn good fine edge stability and its darn tough. I am guessing that Blue and 1.2519 are similar. Achim told me that you can run 115W8 up to 64 Rc for kitchen knives, but if you want to pound it though nails, you might want to try 62RC. Pretty impressive.
115w8 is one of the German tungsten based alloys.
Yes. I mentioned it because it excluded it from the fine edge stability list.![]()
will you do your own heat treat? if yes, 52100, O1, or 1.2519 would be good choices. heat treat is pretty straight forward, don't need cryo. temper at 300F to 325F for hardness of Rc64 I would use 3/32" or 7/64" thickness, 2" wide stock. for first time, i would go for 6" to 8" blade length. yes the steel may rust and discolor, just have to learn to clean and double dry promptly. do full flat grind to an edge around .5mm/0.02" before heat treat, then finish the edge at 7 to 10 dps.What is the best steel to use for a chefs knife. Im making my own knives. I was concedering using AEB-L stainless steel. Any opinions.
Hey I'm curious as to which brand of culinary knives uses that 115w8 German steel? Also I use a lot of Spyderco's knives in the kitchen and the two steels I like a lot for kitchen use are VG-10 and MBS-26. But I've also found ZDP-189 to cut like a laser on certain food items ( especially meat) but a little warning on ZDP-189>> it is highly prone to corrosion with certain food acids ( especially tomatoes) and you absolutely MUST clean the knives with ZDP immediately when done using. If you don't you will be sorry I can assure you.
Also I find Spyderco's H-1 to be a good kitchen/culinary blade steel as well. And it's unbelievably corrosion resistant. Interesting thread!
