- Oct 27, 2006
Can you professionals explain the difference between a jackknife and a peanut, please?
A peanut is a specific pattern of jack knife.
What's the difference between a beer and a lager?
The former's the generic catch-all term, the latter's the specific style.
marcinek nailed it.
A peanut is a small serpentine jack. But the peanut name is given to a small serpentine jack that has a distinctive direction to the serpentine curves, with a distinctive downturn to the front bolsters towards the back springs of the knife. Thjere are similar serpentine small jacks, but without the distinctive turn to the front bolsters, they are more of a dogleg jack.
A Case peanut with white delrin scales. Note shape and direction of front bolsters.
[/url][/IMG]
Thank you, sir - your explanation was exactly what I was looking for. Much appreciated.marcinek nailed it.
[/url][/IMG]
My understanding is that a jack knife is a slip joint that has a large main blade and a smaller secondary blade, both on the same end. Usually, but not always, the secondary blade is a pen blade, as is the case with the Case Peanut. But, a harness jack will have an awl as a the secondary blade and a cap lifter jack will have a, well, a cap lifter secondary. Arguably, the Barlow is the quintessential jack knife.
Pen blades and pen knives should not be confused. As noted above, a pen knife is a 2 blade slip joint with the main blade and smaller secondary blade on opposite ends and typically the secondary blade on a pen knife is a pen blade.
Lastly, when both blades are the same length and on the same end, I'm not sure what they are called. Muskrats, Trappers and Electrician (TL-29) knives have 2 blades on the same end but as far as I can tell, are not typically called jack knives as both blades are the same size.
I believe Trappers are jack knives (blades on same end). The muskrat has blades that open from each end usually.
The Peanut is actually a very specific knife design/pattern and not just closed length. It was shaped like a "peanut". But many people will refer to one or two bladed knives that are 3 inches or less as peanuts. As you said, pen knives are not to be confused. But I stay confused most of the time personally.
Serpentine is another term that confuses me relative to slip joints.
There are dozens upon dozens or patterns of both pen knives and jack knives, with any number, type, and arrangement of blades and springs. Again, check out Levine's Guide.
And one could argue that any one of many patterns is the quintessential jack knife. Not sure what makes a Barlow more special than any other pattern.
Don't have access to Levine. Does he make any distinction on blade length for a jack knife. That is, does he consider a Trapper or Electrician a jack knife?
As for the Barlow, I rather suspect that more Barlows have been produced and used (at least here in the US) than any other single jack knife pattern. Just my guess.
