Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
It's so that you can sharpen the entire cutting edge without cutting into the ricasso, or leaving a dull portion ahead of the ricasso.Is there any real practical reason behind it ? I'm curious.
Daggone, now it makes sense. I've been dragging my secondary knife blade through it like a carbide sharpener. No wonder it didn't work worth a hoot.
Ah, common mistake! Although it can double as a wire stripper!Daggone, now it makes sense. I've been dragging my secondary knife blade through it like a carbide sharpener. No wonder it didn't work worth a hoot.
It’s there to catch on things and make your job harder.![]()
Well I mean if you really look at it, the amount of blade that can't be sharpened because of the lack of a sharpening choil is probably about the same as the amount of the blade that gets ground off to make a sharpening choil...I don't see how people get by using only 99.98% of the blade...savages.
this is not idea for sharpening. Almost always looks bad and not the right way to sharpen.
That's not the point. It's not about not sharpening the whole edge, it's that the sharpening stone rides up on the unsharpened part by the ricasso, which in the long run will lead to an unevenly sharpened or slightly deformed edge, because some parts of the edge will receive different amounts of pressure from the stone.I'd rather endure 1% or 2% of the blade being unsharpened or poorly sharpened rather than have the sharpening choil catch on everything - as they do. They may only be 2% +/- of the blade's length but seem to be in the way snagging on things a highly disproportionate amount of time.
