Currawong
- May 19, 2012
We’re at the Busse forum, so we probably all own a big knife or two. Well, why do we buy them, apart from doing it for fun? Who actually needs a knife that big? If you want to split wood, an axe is the best tool for the job. If you want to cut a branch, its a handsaw. For cutting logs, its a chainsaw. To pry something, use a prybar!
But consider this scenario: You have a job to do. You’re surrounded by every tool known to mankind. And the tool you reach for is that big knife, not for fun, but because in this case it will do the job better than any other tool available. This thread is about those times when a big knife clearly IS the best tool for the job.
Post your scenario about when you need to have a big knife to get the job done!!
^ My dad and I are currently building a wood shed, and we were putting the corner posts in stirrups and trying to get them to sit dead upright. We were using braces - bits of timber at an angle - to hold them straight, and went to peg the bottoms of the braces to the ground to hold everything steady, and ……. we had no pegs!! We looked around and there were none anywhere on the property. We didn’t want to drive into town to buy some. My dad found a bit of timber and got a hand saw and cut an angle off the end, to create a ‘chisel ground’ stake, but it took a long time and wasn’t very sharp and was difficult to pound into the rocky ground.
So I grabbed a bunch of sawmill off-cuts we have for fire wood, and a big knife, and chipped them into stakes. It was fast, easy, and made very sharp and pointy stakes in just a few minutes. For this job, there was no better tool than a big knife. This is the scenario in fact that got me thinking about this thread.
^ There are lots of sticks around my property (it is half forest) and I have two fire places which are the only source of heating in the house. So I go through a lot of firewood including a lot of kindling. You can just break sticks on your knee, or by standing on them, but it is relatively slow, at least if you are going through a hundred sticks or more (and hurts your knees eventually). A big knife makes short work of it. Many of these sticks get cut through with one chop, which takes about two seconds. I’d guess producing a pile of kindling is about three or four times faster using a knife than any other technique I can think of.
^ I also produce kindling by splitting sawmill off-cuts. I normally see people do this kind of thing with an axe. But an axe is awkward, slow, and runs the risk of cutting your fingers off. Don’t do it this way Rob!! Batoning with a big knife is safer, faster and more accurate than anything else. A Busse will hold its edge after weeks and months of doing this.
