Where can I buy Potassium Permanganate?
I want to try some as a dye on stag.I would like to know any business you folks have had good dealings with that sells it.
No such luck here.I have tried 3 and they either said I couldn't get it over the counter,they didn't have any or they acted like they thought I was nutts. There are only 3 drug stores within 30 miles.
Is there a trade name these nit wits will know?
Yep, you need a prescription to get it from a drug store any more. It's used to treat foot fungus.
It's also used to treat aquariums and swimming pools. . .
If you just want a little dab of it, do as Johnny Warner suggests and go to a feed store, and ask for the "purple stuff" that goes in baby chicks water.... it comes in little tablet form.
I just tried a couple of places.They said they did have it but it was taken off the market a couple years ago.
Thanks anyway.
Randy
PP can be had from a dozens of places on Ebay. It is an oxidizer...not a dye...thus the reason for banning local sales...it is explosive under the correct conditions...or incorrect...as it may be. I lb will color 20 lbs of stag easily.
Check the big box stores in the water softner section.
Stan
I would go to farm centre, or drug stores . All else fails call a vet they might have a little to spare . Its really cheap 1 oz will treat 5 gallons of water. you only need 1/10 th of a teaspoon to do a bunch of horn . Dnt mix it with anything other than water. I had a bad reaction happen when I mixed it with some dye it nearly caught fire. kellyw
Thanks everyone!
How much PP should I mix with how much water to dye horn? Can I mix it in a glass jar and use it for some time? Anyone know how long it will keep?
I will take care in how it is handled.
Try a pool supply. Have used it to dye a powderhorn throat. Mix with glycerin to make fire. My batch came from a pharmacy in a small amout. Used at one time for disinfection.
You can purchase any where between 30 grams and 500 pounds from manofohm.com. it comes with a msds label and is shipped fast. a truly quality product.
Saturate the P.P. in the water-until no more dissolves.
I use it in a plastic cup, and add water when I need to use it. I use it on Qtips. A brush will work, too. You only want to color the outside of the stag.
I just let the solution dry up and add more water when needed.
