- Sep 5, 2017
Looking for torx fasteners for swiss army knife alox scales thanks!
Thanks for the reply. Definitely grinding off the key-ring loop. Just thought it would be a nice option to have a lanyard/bail given the size.It's doable, but definitely not easy. I've never looked for 3mm OD hollow tubing but I can't imagine it's readily available... and peening hollow tube sucks. Maybe find a used Wenger Soldat? In the 90s they used a hollow pin with a bail.
The pins are pretty thick stock, I bet you could take it into a machine shop and the could take a 2mm hole out through the center of the pin for a couple of bucks. If you had a drill press with a vice you could probably drill it yourself but if you still it *slightly* off center... then I'd happily buy your ruined knife for parts on the cheap ;P
Or just grind the keychain off and carry it like that
who did the mods?View attachment 853212 Most of the ones I have seen are customs with Titanium scales.
