What kind of fire type things do you want to make?
If you make a candle, mix in a little paraffin candle wax to lower the melting point just a little. If you use a wick from a tea candle, it has never produced enough heat to melt pure bees wax and the wick just burns up instead of burning melted wax.
Don't add to much or you keep the melting point low enough to where it can still make a mess in your kit in hot climates. What ever you do, make a few test burns. A friend of mine said he used a larger wick to produce more heat and the bees wax melted fine. I don't know.
These are some of the reasons I went to oil candles, plus I have oil to start a fire which is better than wax chunks on some wood.
I took a couple pictures, I stink at taking pictures, but you get the idea. You can see the candle I made burning itself out. I made one out of a 12ga base as I wanted a smaller candle, but even that did not work. It works for about 15 minutes and then starts to die FAST. So don't be fooled and fire it up in the house for a couple minutes and think you are good to go, because you are not. As the wick burns up, the less heat you have and the more the wax hardens, and the less melted fuel you have until the wick if gone.
Just look from when I fired these up and how little the wax melted, and how the flame died with almost no bees wax gone or melted. In any fire kit using bees wax, I would mix and test burn to completely to see how long it will last and if it will even work.
This is a regular tea candle to compare flame size.
This is my bees wax tea candle and 12ga base bees wax candle after about 10 minutes or so.
Here it is almost dead after about 15 minutes.
