From heavy work to lighter duty:
SYKCO 1311, basically a golok. I love this thing for trail maintenance. I suspect this is not what you're looking for so I guess this is just for showing off. 13.5" blade I think. SR101/52100
SYKCO 911, (mine is a military over-run, biggest difference is the pointier tip). 9.5" blade of 52100/SR101. A more compact trail maintenance knife that can still do some bigger knife tasks and some of the smaller knife stuff as well. I wouldn't want to be cutting too many notches but it will work for fire prep and food prep just fine.
Swamp rat ratweiler, 7.5" blade. Probably my favorite knife for doing a little bit of everything. Easy enough to carry and it can just do a ton of work in a medium sized package. I have the thin cut versions, the thick cut was .25" which is too thick, IMO. I recently picked up some more, though the orange one is more for looks than use at this point as I don't want to hurt the coating yet. SR101/52100, and infi on the middle.
Moving down to the more wood crafty sizes, LT wright bushcraft Mark II. Great knife. If I could have one knife, it would be between this and the ratweiler. A2 steel on a 5.25" blade. 2nd from the top (from top to bottom, BK62, bushcrafter Mark II, genesis, bush baby)
This is one I'm a fan of but as it only recently finished up from the maker I can't claim it as a favorite yet but I did have it designed based on my uses and desires for a woods knife so I suspect it will continue to move up the chain. Vandis 4e, 5.5" blade, with a slight forward lean to get the belly in front of the knuckles and 4mm thick. Kind of like a small kuhkri without a recurve so sharpening is easy and there is a flat section in front of the handle for carving. The forward belly is nice for cutting against a hard surface like a cutting board or for chopping using a snap action. The forward cant also makes it great in a reverse grip, which I found useful when debarking logs for structure and furniture building (side hobby). It also allows a little bit of use like a draw knife but it's a bit short there.
