I personally used a EDC prybar all the time when I was working, not so much now.Want an honest answer, or a feel good answer?
Here's the honest answer:
You aren't going to use an EDC pry bar, so it doesn't matter which one you buy.
We buy toys like this to feel good. To distract ourselves from reality for a little while. Nothing wrong with that whatsoever, because we all like to feel good. But once every 4 years when you open a paint can, you can use a wide screwdriver or the little gizmo they give you at the paint store. You'll never have an emergency pry job on the way home from Chic-Fil-A. "Thank goodness I had that 2" County Comm pry thing with me!"
The same holds true for EDC fire kits, water purifier straws and paracord bracelets. These are the grownup versions of binkies and blankies and pacifiers. They serve to distract, but that's about it.
I'm qualified to give an honest answer because I've spent 35 years buying and hoarding thousands of dollars worth of this kind of crap. I know what I'm talking about. You aren't going to use any of it. Its there to make you feel good.
So buy the one that makes you feel the best. You yourself said you wanted it to be "cool".
But just admit to yourself that you will never use it. Present company excluded, of course. You guys who use your EDC pry bars 20 times a day.
#paradigmshift
I don't think we're talking about crowbar's. EDC prybars are generally smaller than 4" not really useful for breaking and entering.EDC items which could be mistaken for burglary tools do not promote cordial relations with law enforcement. This is obvious but easy to overlook if you haven't had the experience.
I took one like the blue one pictured above cut it to the length I wanted and rounded the end with a dremel drilled in lanyard hole with a tapcon bit . I use it often at work not so much outside of work
