Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Good to know. I'll see about ordering a tube of it.CRK is the only I will use. I have tried everything.
It would seem that there is a lot more to the grease than I had previously thought. Thank you for your insight.Molybdenum or Moly Grease is the best you can use as far as grease goes. It usually has 3% or more molybdenum.
Moly paste is even better when you can find it, it has a higher volume of moly and is used for intricate parts with thin or small baring surfaces or where the weight of the grease changes the
velocity of a part etc. Moly paste usually has about 15% moly. I've used it for competition triggers in my match rifles over the years, I have also previously dry moly tumble coated my bullets.
There is a product called Tetra Gun which is a moly paste that works well for knives also. Any of these moly pastes or greases need to be injected or some how properly deployed onto the baring surfaces in order to work properly.
If your willing to order that you might as well get the CRK grease.
That was my experience with the white lithium grease. I feel the same way and will use it from now on since a 1.5oz tube can go a long way and is readily available.I went to Ace Hardware and bought a three dollar tube
of White Lithium Grease today. I disassembled my Sebenza, cleaned it, dried it, and reassembled it with the Lithium Grease.
It feels exactly the same as it did with the proprietary, factory lube from Chris Reeve. It opens smoothly with the same amount of drag. It can be thumb flicked open with the proper technique.
I'll probably stick with WLG, not so much for the lower cost. But rather for the general availability. I know that where ever I am, I can take down and clean my equipment as long as there is an Ace Hardware, Home Depot, Lowes , etc...nearby.
