- Mar 8, 2008
Thank you and thanks for your prompt reply too, Benjamin!
I noticed the shortness, but didn't figure out the reason for it. Makes sense. Thanks for the education. I figured I'd at least need to mill or drill a new hole in the heel plate or perhaps I could "hook" the tang knob off the edge of the heel plate and get the correct hafting angle. If anything, it looks like the ARTI tang heel set is too much of a half mulay geometry for the Seymour heel plate too, so the nib might need to be located off the edge of a standard Seymour heel plate or a wider heel plate might be fitted with a nib hole farther to the right (when viewed from the position the scythe is held or "presented", to use a firearms term). Sadly, as you point out, the ARTI tang might be too short to work with the Seymour heel plate regardless.
BTW, scythe nomenclature is still not second nature to me and I incorrectly referred to the hafting angle as a function of the lower end slope of the snath shaft. Rather, it's the correct lay of the blade that depends on getting the angle of that lowest snath shaft section correct (an angle that's dependent on both shaft bend and user physiology), given the tang angle. On the other hand, hafting angle is of course affected by the blade's heel set.
Your best course of action under those circumstances (making it work rather than using different hardware or a different blade) would be to cut new holes in the plate. You'd need to make them rectangular to accept the shape of the knob (really more of a tab in the case of Arti blades.) Nibs are the adjustable side grips of the snath, not a part of the blade. The lay of the blade is a combination of the curvature in the neck of the snath, your dimensions and how you've positioned the lower nib, your stance, and the angle of the tang, among other factors (like the slope of the ground.) The set of the heel impacts the hang of the blade (the "yaw" in aeronautical terms) but it's uncommon to find heel sets other than square on blades that aren't meant for grain cradles.
Yes--I love your North Star ring and heel plate but probably won't order them at this time, because it seems that you plan to provide them with your Longfellow snath soon, which is of keen interest to me.
Yes, we're just waiting for our machine shop contractor to get their new plasma cutting table so we can offer the parts at a much better price than when they were water jet cut. They should have it before Spring, though they're still waiting on it.
Thanks for your assessment. You are probably right. If the fit is still not going to be ideal for this 6'-1" soon-to-be mower after bending a Seymour snath in a homemade pipe bender, I might as well start with raw tubing and just bend the whole thing!
In addition to the Longfellow I'm hoping to be able to offer big-n'-tall sizing in a more traditional two-nib American snath, but it won't be until after we're able to have a standard sized one done up. Our steam bender has a rather rare snath from my personal collection at the moment that I'm having them copy the lovely curves from. They'll be making the bending forms such that they'll be able to scale the form up or down.
If I don't end up buying the Grizzly wet grinder, what's your advice about using your BYXCO "Manticore" Abrasive File for the initial thinning of ARTI blades?
I'd suggest one of our grinding points instead. You just chuck it up in an electric hand drill and use it at an angle just a touch above flat and it'll grind a nice low bevel without running into clearance issues. It'll be much more pleasant, trust me.
Great! I think it will be a simple matter to make clamps to hang bolts with rollers on them from the existing guides--much like what you did with your grinder from below. (There's no underlying structure outboard of the grinding wheel on the Grizzly Anniversary grinder I'm considering though, so only a single guide could sprout vertically from the grinder chassis itself or its guide fittings.) I think the guide rollers could most easily come down from above, or more easily down at an angle off the existing guide structure. On the other hand, I think it's preferable to have vertical roller guides, as you have done. It helps when eyeballing the grind angle. The eye (brain) tends to know where level and vertical are located.
I don't even use roller guides at this point and just grind at a 45° slant to the wheel, as was one recommended historical practice. But they're handy for folks getting used to using a wheel. It's not the same as using other abrasive methods and takes a bit of getting used to. At least with wet grinders they're pretty slow so you aren't likely to outright ruin a blade without getting plenty of visual warning first.
I'm now thinking that I should take a walk or two and look for some vine maple wildwood that I can play with while I wait for you to complete the Longfellow snath project. I can try to find wildwood of a suitable diameter with the bark. In my experience it takes about a year of drying to avoid checkering and I don't want to wait a year, but any debarked areas can be painted with wood glue to greatly reduce the chances of checkering. I know this from slingshot and longbow fabrication. I'm sure someone somewhere has made a snath from vine maple. Vine maple is very curvy and small in diameter. It seldom grows higher than about 20' tall. It has become a very popular wood for longbow making and, everything considered, many bowyers consider it to be the equal of Pacific or European yew, though it is worked quite differently. All maple species have roughly the same density, which is much lower than hickory, as I recall (which is a good thing for a snath).
In the meantime, a cut off piece of large pipe and a wooden wedge would work for affixing the blade if putting together a wildwood snath. It can just be difficult making a good one when you don't already have a strong understanding of how the different parts all need to sit in relation to one another.
