I've been experimenting with a wide variety of blade fitments and I noticed that my loop bolt and nut threads were starting to gall and seize a little. A tiny dab of anti-seize paste solved the problem and the nut now rotates freely on the loop bolt threads again. Similarly, my search for optimum nib positions was turning the rubbing surface of the wooden nib grips into sawdust from all the rubbing of the wood against the rough cast nib blocks. This friction also made the nibs more difficult to tighten. A little dab of Super Lube (silicone grease with PTFE) rubbed onto the wood and dabbed onto the mating surfaces of the nib blocks resulted in the grips turning much more easily. Another smear of anti-seize on the nib band threads didn't hurt either.
We have a variety of grasses in our lawn areas and I'm having trouble mowing some of them. The scythe slices through the flatter and broader variety grass blades nicely, but any fine round grass blades badly want to fold over and evade the edge of the blade.
I found this photo of fine fescue grass online. Maybe it's my nemesis grass variety:
Or maybe it's creeping red fescue:
In any case, our grass is not as dense as the grass in the the above photos, which isn't helping either, because there's plenty of open space in the sparsely packed grass for the blades of grass to fold over without much resistance.
My 66 cm Arti blade mows the fescue grass more effectively than my 30" Seymour Midwest blade (current new production). The Arti blade is much thinner and its edge bevels are much lower than the Seymour, so I figured I'd work on lowering the angles of the Seymour bevels. Unfortunately, when presenting the top of the Seymour blade edge square to my 10" Grizzly wet grinding wheel, the wheel can achieve a bevel that's barely lower than about 16 degrees from dead flat, because the wheel contacts the blade's chine too soon to grind lower. (I measured it and a planar surface hits the chine almost exactly at 16 degrees.) Because of the chine contact, it is impossible to obtain anywhere near the desired 14 to 18 degree included angle with symmetric top and bottom bevels (based on FortyTwoBlade's recommended 7 to 9 degrees per side) while grinding square to the wheel.
Still looking for lower bevels, I decided to try regrinding the edge presented at 45 degrees to the wheel, as described in the book that FortyTwoBlades linked early in this thread:
https://www.bladeforums.com/threads/who-else-uses-a-scythe.884115/page-7#post-10074958
I found that I agree with the book's author; grinding against the rotation of the blade worked better than grinding with the wheel for me. I've always heard that grinding against the wheel removes material faster, but I found that following the author's advice did in fact help to keep any thin pieces of edge from separating from the blade, despite my new lower angle bevel, and it's much easier to avoid rounding the edge. The 45 degree presentation angle also permitted a somewhat lower grind than grinding square to the wheel, but I can't say one way or the other about the alleged benefits of the 45 degree scratch pattern, which the author advocated for its serrations effect. Still, perhaps it helped too. I ground a much shorter and lower angle asymmetric bevel on the bottom bevel. My current production Seymour is not a laminated blade and I'll know to grind the edge symmetrically to the center, if I ever find a classic laminated one
Now my Seymour blade edge features an included edge angle that rivals the Arti blade--something less than 20 degrees. It's difficult to measure such a fine edge angle, but I'd say it looks like about 17 or 18 degrees when I place the Grizzly 20 degree blade gauge next to it.
The new grind improved the performance of the Seymour, but there's still plenty of room for more improvement and I'm open to suggestions for mowing our fescue grass for sure. Should I try a file for yet another scratch pattern? I plan to eventually try a Baryonyx Knife Company grinding point, because its geometry can produce a symmetric 7-9 degree low angle per side grind. (It'll go as low as you want to go!) I'm currently honing exclusively with an Arctic Fox scythe stone followed by a whipping stick. I really like the Arctic Fox. It cuts super fast for its fine finish and the shape is very versatile. If I condition my Grizzly wheel with the fine side of my Tormek stone grader before the final grinding pass, I don't see any need to hone with an intermediate grit hone before the Arctic Fox.
In truth, I'm not all that concerned about the fescue grass, because the blade cuts timothy very well (even when fairly short, as it is now). Livestock feed is my main application for the tool, but I figure the better I can learn to mow the fescue, the better I'll be able to mow our timothy hay pasture later in the summer.
