Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Here are some clues, quoted from
The working of steel, annealing, heat treating, and hardening of carbon and alloy steel
by Fred Herbert Colvin, Kristian A. Juthe, published in 1922
According to this, the Latrobe Steel Company in 1922 produced "Axe Temper" steel (for making axes, chisels, etc.) with 1.00 to 1.09 percent carbon.
A little further in the book from 1922, some specifications for another company's steel used for making chisels are given:
carbon, 0.75 to 0.85 [percent]
manganese, 0.30
silicon, 0.10
sulphur, 0.025
phosphorus, 0.025
Compare this to the current specs for the Forest Service FSS axes:
"3.2.1.1 Steel composition. The tool head of each type of ax shall be forged from fully killed plain carbon AISI/
SAE steel containing
0.72 to 0.93 percent carbon,
0.30 to 0.90 percent manganese,
not more than 0.040
percent phosphorus, and
not more than 0.050 percent sulfur."
And compare to the steel currently used by Gransfors Bruks:
1055 steel composition (not exactly what GB uses, but reportedly "very close"):
carbon 0.55-0.65
manganese, 0.60-0.90
phosphorus, max 0.040
sulfur, max 0.050
Later in the 1922 book, a table of tempering temperatures was given:
(The 8-minute tempering was listed as an quicker option for "rough work".)
Sources:
http://books.google.com/books?id=jWNJAAAAYAAJ&pg=PA10#v=onepage&q&f=false
http://www.fs.fed.us/t-d/programs/fire/specs.htm
http://www.fs.fed.us/t-d/programs/fire/documents/5100_9D.pdf
http://www.bladeforums.com/forums/showthread.php/1017665-Gransfors-bruks-steel
http://www.steeltalk.com/composition_of_steel.php
Axe steel hardness:
from FSS specs:
3.2.1.2 Hardness. The ax bit shall have a hardness of 54 to 58 inclusive on the Rockwell C scale. This hardness shall extend to a distance of 1-1/4 inches ±1/4 inch back from the cutting edge. Within 1 inch of the eye of the tool, the steel hardness shall not exceed 45 on the Rockwell C scale. All hardness values shall be determined as specified in 4.5.1.2. The specified hardness shall extend through the entire thickness of the tool head steel.
from Council Tool site:
ANSI Standards call for bit hardness of Rc 45-60, at least ½ inch back from the cutting edge. Council Tool internal standards call for tempered bit hardness of Rc 48-55 and we target 1-1/4 inches from the cutting edge. The poll and eye walls are not hardened and remain in the as forged condition.
http://www.counciltool.com/DisplayCategories.asp?pg=displaycategories&category=10
Council Tool's premium line of Velvicut axes uses 5160 steel, hardened to Rc 50-54.
http://www.counciltool.com/DisplayCategories.asp?pg=displaycategories&category=79
I also want to add my thanks for providing this. I am not sure if I'm reading the notes correctly but doesn't Council Tool's minimum standard fly in the face of the specifications listed in the first part? Even their Velvicut axe line seems to be short of the recommended RC scale.
...doesn't Council Tool's minimum standard fly in the face of the specifications listed in the first part? Even their Velvicut axe line seems to be short of the recommended RC scale.
That "you get what you pay for" is hardly a recent jingle
Council still makes a FSS version of their pulaski.
http://www.counciltool.com/product.asp?pg=product&item=38PE136FSS
Wetterlings seems to have a similar formula to GB and the way they heat treat the steel. Hardness is listed as Rockwell C 57.
I wonder what some of the other maker's have/use?
We use 1095 in the bit which runs down the center of the blade. .....
The throwing hawks are hardened to 35-40 Rockwell and the Camps and spikes to the mid 50s.
