Flatness: Properly set up belt > Disc with hard face > Hand lapped on surface plate > Surface ground (on a real SG)
Where they actually measure I don't know but would guess something like ~.010" > ~.005" > ~.002" > ~.001"
Actually, this would be a good experiment. I'll flaten some test pieces, set them up on 3 points and indicate flatness on a surface plate. If someone wants to send me a plate they've flatened with either a belt converted surface grinder or a 2x72 surface attachment, I'll include those results. Something like a 2x4" coupon.
Good points there!! I love my real SG for getting stuff flat... but I always have some bowing on folder blades that I can't remedy unless I grind the other side, and even then it's not perfect. I've tried everythign from flood coolant to only taking 1-2 thou passes. So I always finish up by hand on a granite plate w/ sandpaper.
I should have added "with glass platen" which I would think should be pretty flat. I grind scales on platen and when I hold them together to the light, there is no light showing thru. Am I missing something there?
Please do understand, I'm not trying to be difficult or argumentive, just trying to understand.
I can understand your perspective Ken. I've just not felt a need to get one to date either. I'm not afraid of the purchase, I just can't figure what I would do with it that I can't do already.
Maybe it's because I almost never do FFG's, or folders. ?
