- Aug 30, 2014
During a video by a fairly well-known, slightly controversial knife-maker, he made comments about VG-10 and N690co that somewhat typified the strange double standard that exists in the knife industry. Mentioning a couple Seki City Spydercos, he made some allusions to VG-10's sub-par edge retention, and suggested it was a decent steel that was good for less expensive knives, but not premium. Fair enough. I don't mind VG-10; it takes a very sharp edge, and has good-excellent corrosion resistance. But it's not one of the particle metallurgical steels that have become the new standard for high-end knives.
Later in the video, however, he refers to Bohler's N690co as one of the better all-around blade steels. I'll say now that I'm not trying to insult or embarrass someone for their opinions. There's nothing wrong with speaking your mind about likes and dislikes when it comes to materials, especially when you're a respected knifemaker. I politely asked him about the differences between VG-10 and N690co, but never got a reply. That's fine too. He's busy. But it's not just him.
Todd Begg uses N690co almost exclusively, on knives ranging from 700-2000$. If he switched to VG-10, I think you'd definitely hear some pissed off Begg fans. Curtiss Knives uses it extensively as well. For overbuilt, hard-use folders to be using a VG-10 equivalent seems a bit unlikely. It's definitely cheaper than the PM alternatives, though, and easier to work with. Whether or not those are appropriate criteria for a maker to consider when selecting blade steel, I can't say; I don't own knives by either maker, and that's an issue for a maker to take up with his customers, or vice versa. I will say that I'd love to own knives by Begg or Curtiss. I don't really like the Field Grade Begg models, but the Beggatti and Bodega 2.0 are great-looking designs. Ditto for the Large F3 and Cruze Evo by Curtiss Knives. I don't recall hearing a bad word said about either makers.
So what makes N690co better than VG-10? Their specs are almost identical, and because neither steel is a powder metallurgical, the percentages vary more between individual batches than they do between steels. The only notable difference is that N690co has a slightly higher percentage of Chromium. VG-10 is listed as having 14.5 - 15.5% Cr, and N690co is listed at 16.0 - 17.5% Cr. Without the homogeneity of PM steels, some VG-10 blades may have higher Cr levels than N690co. Then there's the question of whether an extra 1% chromium would yield any significant differences...
I don't know. I have no idea, because I've never owned an N690 blade. But I'd like to know if N690co has indeed been blessed with subtle powers, or if the trace elements make a noticeable difference. Even if that Bodega 2.0 is rocking European VG-10, it probably wouldn't keep me from buying. The 1300$ might, though.
Generated 11797271 times.
[TABLE="class: stlDataDef"]
[TR]
[TH="class: stCname"]Name
[/TH]
[TH="class: stCbase"]Base
[/TH]
[TH="class: stCC"]C
[/TH]
[TH="class: stCCr"]Cr
[/TH]
[TH="class: stCMo"]Mo
[/TH]
[TH="class: stCV"]V
[/TH]
[TH="class: stCW"]W
[/TH]
[TH="class: stCCo"]Co
[/TH]
[TH="class: stCNi"]Ni
[/TH]
[TH="class: stCMn"]Mn
[/TH]
[TH="class: stCSi"]Si
[/TH]
[TH="class: stCS"]S
[/TH]
[TH="class: stCP"]P
[/TH]
[TH="class: stCCu"]Cu
[/TH]
[TH="class: stCNb"]Nb
[/TH]
[TH="class: stCN"]N
[/TH]
[TH="class: stCtech"]Tech
[/TH]
[TH="class: stCmaker"]Maker
[/TH]
[TH="class: stCcountry"]CC
[/TH]
[/TR]
[TR]
[TD]N690Co(SE)
[/TD]
[TD] Fe
[/TD]
[TD]1.05-​1.07
[/TD]
[TD]16.00-​17.30
[/TD]
[TD]0.80-​1.10
[/TD]
[TD]0.00-​0.10
[/TD]
[TD]0.00
[/TD]
[TD]1.50-​1.65
[/TD]
[TD]0.00
[/TD]
[TD]0.40
[/TD]
[TD]0.40
[/TD]
[TD] ?
[/TD]
[TD] ?
[/TD]
[TD]0.00
[/TD]
[TD]0.00
[/TD]
[TD]0.00
[/TD]
[TD][/TD]
[TD] Bohler-Uddeholm
[/TD]
[TD] SE
[/TD]
[/TR]
[TR]
[TD]VG-10(JP)
[/TD]
[TD] Fe
[/TD]
[TD]0.95-1.05
[/TD]
[TD]14.50-15.50
[/TD]
[TD]0.90-1.20
[/TD]
[TD]0.10-0.30
[/TD]
[TD]0.00
[/TD]
[TD]1.30-1.50
[/TD]
[TD]0.00
[/TD]
[TD]0.50
[/TD]
[TD] ?
[/TD]
[TD] ?
[/TD]
[TD]0.03
[/TD]
[TD]0.00
[/TD]
[TD]0.00
[/TD]
[TD]0.00
[/TD]
[TD][/TD]
[TD] Takefu
[/TD]
[TD] JP
[/TD]
[/TR]
[/TABLE]
[TR]
[/TH]
[/TH]
[TH="class: stCC"]C
[/TH]
[/TH]
[/TH]
[TH="class: stCV"]V
[/TH]
[TH="class: stCW"]W
[/TH]
[/TH]
[/TH]
[/TH]
[/TH]
[TH="class: stCS"]S
[/TH]
[TH="class: stCP"]P
[/TH]
[/TH]
[/TH]
[TH="class: stCN"]N
[/TH]
[/TH]
[/TH]
[/TH]
[/TR]
[TR]
[TD]N690Co(SE)
[/TD]
[TD] Fe
[/TD]
[TD]1.05-​1.07
[/TD]
[TD]16.00-​17.30
[/TD]
[TD]0.80-​1.10
[/TD]
[TD]0.00-​0.10
[/TD]
[TD]0.00
[/TD]
[TD]1.50-​1.65
[/TD]
[TD]0.00
[/TD]
[TD]0.40
[/TD]
[TD]0.40
[/TD]
[TD] ?
[/TD]
[TD] ?
[/TD]
[TD]0.00
[/TD]
[TD]0.00
[/TD]
[TD]0.00
[/TD]
[TD][/TD]
[/TD]
[TD] SE
[/TD]
[/TR]
[TR]
[TD]VG-10(JP)
[/TD]
[TD] Fe
[/TD]
[TD]0.95-1.05
[/TD]
[TD]14.50-15.50
[/TD]
[TD]0.90-1.20
[/TD]
[TD]0.10-0.30
[/TD]
[TD]0.00
[/TD]
[TD]1.30-1.50
[/TD]
[TD]0.00
[/TD]
[TD]0.50
[/TD]
[TD] ?
[/TD]
[TD] ?
[/TD]
[TD]0.03
[/TD]
[TD]0.00
[/TD]
[TD]0.00
[/TD]
[TD]0.00
[/TD]
[TD][/TD]
[TD] Takefu
[/TD]
[TD] JP
[/TD]
[/TR]
[/TABLE]
