"If the steel's clean, cold blue will produce a definite color change on plain carbon steel, regardless of finish."
The blue does produce a color change. In fact, the more layers I apply, the darker the metal becomes. The problem I am encountering is with keeping the blue on the blade after applied. If I wipe with a wet rag, the finish washes off.
"Do you mind telling us how you know your steel is 1095, such as how you sourced it, or was it found steel?"
Nope, I don't mind at all. I purchased it from Scheffield Knifemaker's Supply; they are located somewhere in Florida. Over on Knifeforums, Jerry Hossom posted a knife tutorial link, then recommended people use 1084 from Scheffield's. When I ordered, they were out of 1084, so I went with the 1095... at least, that's what they say it is. According to Hossom, they are a reliable source.
"Hope this helps, some. Good luck."
Yes, it does, indeed. Thanks you on both accounts. I will post further results as I am able to continue working on the knife... hopefully, I will completely finish the blade and complete most of the handle over the weekend.
"In stainless, the key word is LESS. It's not stain proof. It will stain, and corrode if abused, it just has LESS of a tendency than tool steel to do that."
True. I am comparing this current steel to my BM Griptillian in D2, a SOG folder with 440A, and a Cold Steel SRK. The steel I am using stained much, much more easily than either the 440A or the D2. In fact, it stained as quickly, or nearly so, as my SRK will when left in moisture.
"Where did you get this "1095", and when you ground it did a shower of sparks result? Stainless has less of a tendency to spark than tool steel."
As stated above, the steel came from Scheffield's. I ground the blade down a couple of months ago and much of the blade shaping was done with a file. However, when using a Dremel, it will spark all over the place. And, come to think of it, the rest of the bar stock sparks easily when being ground (I bought enough for several knives to be made... my brother, step dad, and several friends have made at least one, if not two, knives from this material).
Thanks for the interest and replies. I am learning even without taking steel and tools in hand!
