- Dec 13, 2022
I've recently noticed a lot of disdain for and ridicule of those using what I see called pull sharpeners. I've gathered that this means any type of sharpener in which you literally pull your knife through a slender opening with some kind of rods in the shape of a V at the bottom.
Honestly that's all I've ever used. They get it what I would call "working edge sharp" and I've been fine with that. I have noticed that they remove quite a bit of material. Is this the reason nobody likes them? Or maybe its the rather obtuse angle at which the rods force the edge to be?
I'll be the first to admit I don't do high maintenance anything. I would prefer to use the best products and apply the best practices in everything I do, but not at the sacrifice of it being higher maintenance to any noteworthy degree.
A long time ago I purchased a couple different highly touted sharpening systems. One a Lansky that requires way more set up and time than I'm ever interested in. The other is, I think, a Spyderco something or other with varying rods that go into various holes in a plastic base that you then stroke your knife through several times on each side. It came with a CD on angles and techniques etc. That one doesn't seem so bad, but I tried it once and felt like it didn't do anything and doing the angle right is all in how you hold it which is a huge margin for error. So i went back to the pull through type. I've got a dozen of them, they all work and get an edge that I've thus far found acceptable.
What's your take and thoughts?
