- Dec 9, 2003
I am putting on new handles onto my seki cut fixed blade.
The handles now aren't all that pretty and they aren't well sealed, therefore meat juices could get inside if i use it for a steak knife etc. There are, i'm assuming, anodized aluminum pieces on the sides and then a piece of wood all held together with two screws. The wood pieces were actually held on with some sort of double sided tape too.
So the problem is, if i'm going to use epoxy to stick the wood to the handle slabs and maybe even the handle slabs to the tang itself, will epoxy stick to the anodized aluminum. Why use the sticky tape if epoxy wouldn't work?
Im probably just going to use the same screws you already see on the knife, though i could replace them with someone like the screws with round nuts that you sand smooth later... Im just afraid that the two screws alone would not create a sufficient tightness to keep stuff out.
I guess i could always just put only wood and that would be of course stick to the metal with epoxy. Im supposed to roughen up the metal to help the epoxy stick right?
Thank you
Thank you
