- Oct 24, 2013
Thanks to a great bit of information I've gained through lurking these threads as a non-member, especially eflemming and Indian George, I've taken on the the challenge of "slowly" building my own hydraulic forge press. I'm not about to go this blindly so I've ordered the appropriate literature that's been suggested by every thread I've ever read on the subject thus far;
Jim Batson's "How to Build a Hydraulic Forging Press ...
I'm not completely enthralled with knives per say, but I can appreciate the craftsmanship a great lot of you strive for. I just enjoy being around hot metal, and figured I'd just as soon give something back to the forum I've been stalking as a non-member for some time now. I will most likely not stick around as far as posting is concerned, as I don't jive with internet personalities, and personally feel the conjecture takes up a great lot of useful forge time.
My temporary list
Motor;
Leeson � 5 HP, single phase 208V/230V- $240 Fleabay
Coupling; Motor>Pump- Tractor Supply
Motor-5/8 coupling-L-090----
Pump- 1/2 coupling----L-090 ---
Flex insert-Buna-N---L-090 --- $13.40
Pump
11 GPM 2 STAGE HYD PUMP- $109.95- International hydraulic US -
4-way control valve-Std 4-Way Cntrl Valve, Model# RD2575T4ESA1--$106.15- International hydraulic US (yet to purchase)
Tank 7 gal. Nortrac Steel Hydraulic Oil Tank 7 Gallon-- $99.99-Northern tool
RETURN LINE FILTER --- $20ish
Cylinder-3000psi 5 Bore x 8 stroke x 2.5 pin - $232.27 - International hydraulic US
Misc. essentials (gauge, hoses, couplings, etc)
Extend SPD- 2.2"/SEC
Retract SPD- 2.9"/SEC
Cycle SPD/Time-
Extend Time- 3.6"- SEC
Retract Time- 2.8"- SEC
Cycle Time- 6 SEC
58905 pounds cylinder push/ 29 tons
The materials that I have on hand seem to be quite conducive to the C frame build, and the C frame will also give me more access to a wider and more unique dimensions of work... My eye caught sight of forklift fork I'd purchased some time ago for a a project that never came to fruition... I think it will suffice as a fine jump off point for the build, but in the same breath I fully understand that it needs added structural rigidity.
I lucked out with the purchase of this clamp on fork, at 5" wide, 2" thick, and 72" long, that webbed support portion being 1" thick plate.. Its weight is comparable to my 275 pound anvil... If it fell on a kitten, you'd never know it was a kitten if you catch my drift...
I know that these forks are most likely 4140, and are designed with bending stress in mind. However, the stress exerted, considering the application is very different than the live-load stress it would likely see in its lifty-forky day job... Preheat is definitely going to be an important factor, and though my rod of choice isn't necessary, 12018 just makes me feel better on the inside.
The few C frame presses I've seen are built like brick-shit-houses, but lack the material excess I've fallen upon through blind luck... The monstrosity that is this fork has to account for shortcuts elsewhere...
My first question for the forum would be regarding the rigidity of the frame, as I'd desire as little flex as possible. The question's more in the realm of a structural welders forte; Can I get away with say W6x12 running the full length of the press or should I up the ante???
Thanks you in advance... I'll update with sketches followed by tangible progress as time permits...
My temporary list
Motor;
Pump
Cycle SPD/Time-
Cycle Time- 6 SEC
