- Feb 24, 2000
I remember seeing a picture of a Wire Damascus blade in a magazine or the Knife annual maybe 35-40 years ago. I thought at that time that if I could ever make something like that I would feel like I had reached the top of the mountain so to speak.
Back then there was no internet, no u-tube, no DVD's, very few books.
I got some 1" cable and using 20 mule team borax and a hand hammer began to experiment in my coal forge.
In 1991 I attended a ABS Damascus class in Washington Arkansas and learned how to forge weld.
A friend of mine owned the local Mine Supply store and got me 20 or 30 feet of 1 1/4" wire rope.
I recently used up all of that wire rope and looked for more. My friend no longer owned the Mine Supply store and they were not interested in getting me a small amount of wire rope.
There was a post here about a source for wire rope. The company was US Cargo Control. I found some "Bright Wire Rope EIPS IWRC-6x37 class-1 1/2". The minimum order was 25 feet but with 26 feet I got free shipping. Including tax it cost $16.27 a foot. The wire rope came in less than a week.
I used my abrasive weel chop saw to cut the wire rope up.
To forge, I used a 5" piece.
When the wire rope is cut up it tends to untwist. I put a hose clamp on the cable and weld the ends up.
Next I weld a handle on the cable.
The cable has lots of oil and grease in it. To clean it I put it in a bucket of kerosene and leave overnight.
With the gas forge going I take the cable from the kerosene and put it in the forge. The kerosene and grease will burn off.
Then when the cable starts turning red I take it out and apply flux.
This is what I use. This flux soaks in the cable and makes a good weld.
When the cable gets to welding heat and I want the cable to be hot all the way through I take it to my hydraulic press.
I use a flat die on top and a V die on the bottom. Working quickly I rotate the billet while pressing down with the top die.
The billet looks like this.
Next I flux and re-heat the billet. Then I take it to my 100lb Little Giant Power hammer. In one heat I flatten the billet. This one came out 14"x1 3/4" x3/16 to 1/4".
More later.
More later.
