- Oct 30, 2002
Well, I finally couldn't live without the improved temp control of a heat treat oven and decided to build one using the design seen on the British blades website.
I have a programable PID temperature controller (thank you ebay), a solid state relay (thanks again, ebay), a 9" kiln-type ceramic insulated K thermocouple (ebay...seeing a pattern?), and I'm currently building the casing.
My question is this. The Kanthal elements I'm using will be wired in series to pull a total of 13amps at 240V/AC and deliver 3100 Watts. They will be powered off of the relay which will be controlled by the SSR outputs on the PID. Am I correct that dryer outlets are typically 240V 20amp outlets? So I should be fine powering the elements off my dryer outlet, right?
Also, the specs on the controller I'm using say it will take 85-260V/AC to power it. Would there be any benefit to running 120V to power the controller, or can I just run it straight off of the 240V I'll be using to power the elements (before the relay, of course)? It seems that since it's rated to take 240V, and the big juice pull wouldn't be going through the controller, it would be fine, but I wasn't sure if there were any longevity issues of 240V vs 120V.
Anyway, I appreciate any help I can get. I'm handy with most things, but I just need some reassurance/advice when it comes to electrical as I really want to be careful (obviously
--nathan
--nathan
