- Sep 14, 2010
Hey all you wood finishing pros,
I applied a thin (by finger) coat of Tru-Oil to the handle of a DOTD Chitlange with Satisal wood handle and it has not dried in over 30 hours. It is still tacky to the touch.
This is what I did which worked fine on a Neem handle.
1) I removed the Jeweler's Rouge with soap, water, and a nail brush. I used as little water as possible and worked quickly to keep from raising the wood grain.
2) waited 24 hours to let the handle dry. This was probably the toughest step
3) Sanded lightly with (about 320 grit) foam sanding block and finished with 400 grit sandpaper using just my hand.
4) Applied the Tru-Oil with my finger using a non-latex medical exam glove (Nitrile).
I did not use paint-thinner or mineral spirits to clean the wood after the sanding. I have done this on other handles when I used Minwax Tung Oil Finish (which I now believe contains almost no tung oil - although it is oil based) and it has worked fine.
Do I need to clean with pant-thinner or mineral spirits to remove what ever the kamis soaked into the wood?
Can I clean off the Tru-Oil with mineral spirits and start over?
