Wood knots in stick tang handles?
I'm working on a knife handle and will be burning the tang into a solid piece of wood. This is just a knife for myself so I'm okay cutting some corners.
My question to you lot, is regarding some Apple wood that I have and adore using for handles, unfortunately the last of it has either been used, turned to kindling, or is covered in knots. Aesthetically I love the look of the twisted grain and knots but I wondered if it would be a bad thing for a knife handle, I know it's frowned upon for axes and the like but this handle won't be under near the shock. What do you think?
Thanks
I have never used wood with knots in it besides what's in a nice figured burl so I can't really comment on that part of it. But I give you a word of caution to burning that handle onto the tang. If I was you I would just drill it over sized and fill it with JB weld. I have seen handles burned on which worked great but usually it involves a wood that will burn easy. If the wood has knots I would think that might hinder you burn. But being that I don't burn in handles or have ever used knotty wood I guess I'm out of advice lol
I say its a good idea. If you like the wood, do it. I use alot curly birch or curly maple.
If you burn it in, I suggest drilling the bulk of material first then burn. It will go much faster & less overburning.
I tried burning on a few knives, its not worth it for me. I just drill & broach to a semi loose tolerance. Then just epoxy to secure & fill any internal gaps.
Yeah, I always pre-drill before the burn.
I've used the same wood in a couple Moras with the same technique but this knife has a bit thicker stock. I hadn't considered the knots being an issue in the process.
As long as the knots are sound, and there's no checks (cracks) in the knots or the surrounding wood, it should make a good handle. Finishing may require a bit of extra care, as hard knots sometimes sand away slower than the wood around them, leaving the knot as a slight bump. Use a firm sanding block and this is less likely to happen
