I have a old 3 phase table saw motor and a Teco VFD and was thinking about cobbling together a grinder. This is just for making stuff for myself as I have no intention of doing anything professionally. Anyway, I have a nice woodshop and was thinking about making some wheels out of laminated plywood stacked up and glued. You can drill a hole in the approximate center, run a threaded rod through it and then mount it flat on a workbench. THen you can spin it into a stationary router mounted at the proper distance from the center and end up with a perfectly round wheel - pretty easy. I was going to use 5/8" or 3/4" shaft through pillow blocks and a flange bearing on the wheel. Seems to me it should work fine. I've been thnking about this for a while, and then last night, I just happened to be watching a Youtube video that Michael Morris did and noticed that he has basically the same setup. I was curious if others had ever used the same set up? If there were an ideal wheel size range for grinding, etc. It'll be my first time off the drawing board, so I figured I'd ask. A search didn't turn up a whole lot.
