- Sep 16, 2002
Ok, so the grin stretched across my face as I type this is making my cheeks sore! I received my Ken Onion edition do the Darex Work Sharp knife and tool sharpener today, and as the title suggests, this thing is awesome! This post turned out longer than I planned, so if you wanna skip the intro fluff, the actual review will be in the next comment...
So it's been a while since I've been real active on the forum, but for those not familiar, with me, a little background. I'm no spring chicken when it comes to sharpening knives. I have a plethora of DMT bench stones in grits from XX coarse to 8000 grit XX fine. I even have several of their folding pocket models, as well as an original model Wicked Edge Professional Sharpening system with diamond, ceramic and strops. I also have a Spyderco Sharpmaker and several bench size strops. I can put a nice, hair whittling edge on any knife I own, manually or with the WEPSS. While my edges may not be to the same level as others here, like Ankerson or Cliff (IIRC), my edges are by far sharper than anybody I know locally.
Now, that being said, while I can put an impressive edge on a knife manually, it's not a quick process by any stretch of the imagination. Needless to say, after I spend any real time working on an edge, I don't want to use the knife for anything harder than slicing air, because I hate to mess up what I did. This was the main reason I decided to get the WEPS. To me, it seemed like it would be much easier to set up and use, and make my edges much more consistent than I could achieve manually. I figured I would be more apt to use my pristine edges for what they were designed... Cutting stuff. Compared to manual sharpening, this was definitely the case. Still, it's not exactly quick, when you factor in dragging the setup out from where you put it up, trying to get the knife put back into the clamp exactly the way it was last time so the stones perfectly match the bevel, and then working the dulled edge back to pristine glory. While I could get a great working razor edge in a matter of minutes, I hardly ever stopped there. I would spend several minutes on each ceramic and each strop with progressively finer polishing compounds, followed by several minutes on the bench strops with chromium oxide and .25 micron diamond spray. What should have taken me 5 minutes max turns into an almost obsessive 30 minutes or more. Sheesh! I'm back to not wanting to use my knife again, LOL.
Well, fast forward a few months. I have all my knives sharp as ever, and had to put the sharpener up to get it out of the way. I see some mention of a new device called a work sharp tool sharpener. I watch the commercials, and I'm intrigued, albeit torn. On one side, I see a little belt sander that is supposed to put sweet convex edges on any knife quickly. On the other side, I see something that screams made for TV Infomercial that should have Billy Mays or Ron Popeil pushing. It looked cheap. Moving on. Clearly too good to be true...
Well, fast forward even longer to now, and I'm getting the sharpening bug again. I actually start looking for a cheap belt grinder with adjustable speed so I could start convexing my edges, and I come across the Work Sharp again. By this time, I see there are some pretty good reviews and even some good videos on YouTube. Starting to think I may have prematurely written off a decent tool. So I start researching it more. Lo and behold, it looks like they've come out with a new, improved model, and gotten legendary knife designer Ken Onion to endorse it. Since it's so new, there aren't too many reviews, but the specs look really nice. 3/4 inch belt, beefier motor, variable speed, adjustable angles, and some pretty cool attachments in the works. What the heck, I think I'll order one... Placed my order on Amazon and bought one through Northern Tools on Tuesday. It came while I was at work yesterday, so I didn't get to mess with it until today.
