So I was asked about a swiss army knife that is 91mm long with two blades. So, I grabbed a Victorinox explorer, which seems to be 91mm long with two pen blades 38 mm (1 1/2") and 60 mm (2 3/8") long. At the end of the day, it is not the blade length that matters, but the blade width. The long blade is 11mm wide and the smaller blade is closer to 9mm wide.
I will try to embed some images and I am pulling them from my smugmug account (
https://pitonyak.smugmug.com/Knives/i-VqfH7bK) since I am embedding small(ish) images
This is the Victorinox with 5mm of the blade clamped and and 7mm protruding
When I lower this to 15 degrees on the sharpener, it hits
Then again, the actual angle observed will be directly related to how wide the blade is. In the picture above, my digital angle measure showed this to be about 16 degrees, but it is hitting the guide; no good. If I raise this to just under 20 degrees, it is probably closer to 21 degrees at the blade, and it does not hit.
For what it is worth, this seems to be about the angle that this particular knife is sharpened at the moment.
Next I tried a Case medium Stockman, nope! Even the widest blade is not wide enough for 15 degrees.
On a whim, I locked a ruler sticking out of the clamps and off hand, it looks like need roughly 20mm of blade sticking out of the sharpener to get 15 degrees. If I have 35mm to 40mm sticking out, I can go down to 12 degrees I believe, but I did not actually try that.
Next, I grabbed a Buck 722 with S30V steel. This still had the factory edge. It came pretty sharp for a factory edge. Buck tells me that they sharpen free hand on belts, as does Case, before they leave the factory. I believe this to be true for both made in USA and made in China Buck knives.
I was trivially able to get this at 15 degrees, which looks like it pretty much nailed the factory grind.
I found out that on one side, the factory grind was far from consistent at the tip, it was way off. The other side was spot on. I had never bothered to touch the edge because it was pretty good from factory for my needs.
I used all three grits for the tip and only two of the grits for the other side. The edge was certainly close to factory. Pretty amazing after I hit it with a strop. I should mention that I strop with my Worksharp belt knife sharpener. I own both the Original Knife and Tool Sharpener as well as the ken onion version. Usually when I "strop", I put stropping compound on an old belt and free hand the strop. It is crazy fast and almost always makes a huge difference.
My primary concern here is that the blade near the handle is concave. The problem with a concave blade is that we a stone that will have problems getting into that concave portion of the blade. I usually avoid concave blades because I cannot easily sharpen a knife on a stone (water stone or oil stone), at least not easily. I also expect this problem with the Spyderco Triangle Sharpmaker, the Work Sharp Angle Set Knife Sharpener, and this Work Sharp Precision Adjust Knife Sharpener. The Spyderco Triangle Sharpmaker you can put the corner out and easily get into that concave area. The same is true of the Lansky Turn Box Knife Sharpener because their rods are round.
To my surprise, the Work Sharp Precision Adjust Knife Sharpener managed to sharpen the concave section with no problem, so I assume that the edge of the "stones" did the work. Surprise surprise, very happy about that.
The end result was not nearly as polished given the progression available. If you are a knife snob (and most of us here probably are), attaching sand paper as shown in the video is probably not a bad option, but at some point you start thinking that the sharpmaker at $500+ is a good idea. Even that, however, will still have problems with narrow blades. They make a narrow blade attachment, which has more clearance and it pushes the blade further out. So then you need to get longer bars. So you need to spend another $100(ish) to add the ability to handle the narrower blades. OK, they might have called it the low angle attachment, so with my pension for these smaller knives, I would need that if i got one. Would sure like someone who has one to tell me the smallest blade width it can handle at 15 degrees (or slightly less).
Given that I paid about $50 at Sharpening Supplies (.com), it seems like a good purchase.
If you want something for a narrow blade, take a look at the Work Sharp Angle Set knife sharpener. I prefer the Spyderco, but the Worksharp supports more angles, but it has shorter stones, less of a selection unless you attach sandpaper to it (and then you need to run the blade backwards), and you are stuck with the flat stones only. On the other hand, the Spyderco cost more, and if you want extra coarse (diamond or one other thing) or the extra fine, that costs even more.
Well, I hope that was at least a little bit informative.
