Workbench for a 2X72 grinder
I am building one to put my grinder on (and disk grinder eventually). The stand I have is just too wobbly. I'll just build a simple sturdy workbench. I was wondering if any of you might have some tips or pearls of wisdom about workbenches.
Pad
I built two, one for each of my grinders, out of 2 X 4s for the frame and white melemine (I think that's what it's called) for the tops. I didn't bother putting the back two legs on - just screwed the back of the frame into the wall of my garage. Simple, but sturdy and cheap.
I had a buddy give me a hand to weld a stand!!this thing is a tank..,i had my 2 wheel grinder on it to begin with,then swapped it out with the kmg :). cost me about $100 to make.
heres my only pic,i need to take some good ones!!
I would love to see full pics of your metal workbench. Even if I'll probably have to settle for wood for now anyway.
I am not sure if I'll go with melamine for the top or just plywood?
As far as height, do you guys grind standing up or sitting down?
Thanks for the help.
Pad
I mounted my KMG so my work is centered on the platen when grinding (standing up).
harborfreight has tool stands for $19.95 Said 300lbs load rate on it. I put a 2" thick top on it and tested it with my 250lb seams solid.
