If you just need to tweak the top edge, Hoopster as the right approach. I sometimes use some aluminum foil as a heat shield so I don't accidentally heat other parts.
Heat the spot until it softens a little, used a gloved hand to bend or unbend the Kydex. Hold it for a minute so it cools and sets. Test it to see if you got the desired results. If not, just reheat it like I do and try again. It usually takes me at least 2-3 reheats to get it the way I want it.
You can wipe a little Armour All on the Kydex, it shines it up nicely.
Ric
