The fact that belt sharpening is bad for edge longevity due to overheating has already been proven time and time again. CATRA testing has proven the fact. Larrin Thomas has a good article on the subject.
That's exactly the reason why most knife edges improve in durability after a few times sharpening on a whetstone.
The edge is infinitely thin to get it as sharp as possible and the friction of a dry belt (even if slow) is enough to bring the temperature to well above tempering temperature in a matter of milliseconds. You'll never feel it happening because it's happening at the very edge of the edge. Belt grinding with constant water flow is another story altogether, that won't affect the edge.
Not saying there is no place for dry belt sharpening, it's still the quickest and easiest way to save time and money and any large scale knife producer would be crazy to hand sharpen every knife they sell but the facts don't lie - it's not good for your edge holding longevity.
If you run the knife hard and oversharpen or allow it to get hot and overdo it. Then yes it can be overheated.
And I tested this with a cheap knife and felt some heat from the blade from going overboard on it.
First off. I dare say your so called facts are wrong in some aspects (Not All). My reasoning is listed in the following long rant and rebuttal.
I run a knife at medium to fast speed with good belts not worn out for 1 or 2 passes and set it down a few or dunk the blade in water after every pass. Then repeat the process. If you take your time and don't overbear or overdo the process. And use belts that are not worn out. As worn belts cause more heat than non worn belts. You will not overheat or ruin your edge. Also once sharpened. Use a honing steel or ceramic rod to keep the edge up instead of sharpening every time the knife starts to dull. That way you can keep sharpening down to once or twice every year or two depending on how much you use it. Proper use of the Ken Onion Worksharp will not overheat and ruin the temper. And I will debate that with Larrin himself who has a PH.D in metallurgy. And who I respect very much. And have read his book. But I disagree even with him on this one completely. And I am sure other Metallurgists and knife makers disagree as well.
I sharpened and also re beveled 5 various kitchen knives for my Godmother. And used the steps I described here and in my first post. I then smacked the piss out of each one 5 times on a hard plastic cutting board and some chicken bones. (Except for my thin Asian chef knife) No chipping occurred. Not even on a very small level. I cannot afford a thermal imaging microscope. But I feel like my test is more than adequate for real world use. Not to mention I saved over $70 on the cost of a professional sharpener.
Where is this test on CATRA you mention? And I want to see the tests and proof on the Ken Onion Worksharp specifically with good condition belts and proper use. Because I have looked for it on both Youtube and internet articles. If the KOWS had these issues of ruining knives. It would be well known by now and there would be a ton of 1 star complaints, horrible posts with proof left on BladeForums, and discontinuation of a product.
Nothing has came up on CATRA listings or internet searches on overheating and chipping blades from KOWS. Except for full sized Bench grinders. And I have yet to overheat a knife on my KOWS or see my edge degrade and chip.
The Worksharp is not some overpowered beast like a full size bench grinder lol. Hell custom knife makers use paper wheels on a bench grinder for final sharpening and polish. Would that not generate heat and cause chips and blade failure? Yeah go tell the professional custom knife makers like Ken Onion and Jay Fisher they don't know how to sharpen their knives lol or know anything about the characteristics of steel lol. They properly use such machinery which avoids overheating of the edge and edge chipping.
I challenge anyone on this forum to try my method of sharpening by properly using the Ken Onion Worksharp and doing one or 2 medium to fast passes then letting blade cool for a minute or if in a rush trying my method of dunking the blade in a bucket of cold water followed by a quick towel wiping of the blade to remove excess water after each 1 or 2 passes on both sides and repeat until you are finished. Then smack your knife on a cutting board for 5 whacks. Followed by wiping the blade edge to remove any wood or debris where you struck the cutting board. And don't use a high Rockwell Asian style kitchen knife for chopping to prove me wrong as they are not designed to chop with being too thin in the edge and body. And have a Rockwell over 63 which makes them hold an edge longer but reduces toughness which can cause chipping when used in an improper manner.
Also another reason some knives improve in durability after sharpening is because companies like Spyderco and Cold Steel tend to overheat their blades during machine sharpening as they are mass produced and not sharpened with much care into overheating. Which leaves a weak chip prone edge on top of chip prone steel such as VG10. After a sharpening on my KOWS chipping no longer existed on my Endura. Which is one reason out of a few why I see these companies as overrated and refuse to own or buy any more of their products after buying a $95 Endura 4 that chipped from slicing a quarter inch thick soft wood branch new out of the box. My Hogue EX-02 was machine sharpened at the factory and I have used it hard without re sharpening yet. But guess what. No micro chipping, edge rolling, or deformation.
Not trying to be a dick or claim to know everything. But until you or anyone else proves me and thousands of KOWS users wrong. I am not buying anything anyone says against the KOWS. I own and have used the KOWS first hand and the results rival that of my factory edge on my Hogue EX-02.
And nether are the thousands of positive 4 and 5 star reviews on numerous sites that sell the KOWS wrong, lying, or fabricated. That fact alone speaks volumes on the reliability and good piece of machinery the KOWS is.
I have not found one review saying my KOWS overheated my edge and caused my knife to chip. I am pretty sure some of the reviewers have metallurgy or knife making and steel knowledge backgrounds. Of course improper use could result in issues. But that is unlikely. I even know 2 professional sharpeners in my area who sometimes use the KOWS to re bevel a knife. Or to sharpen customers knives. And not one customer has complained about edge chipping or retention issues.
You, Larrin, nor anyone are converting me until I see conclusive proof. And it had better be with the KOWS specifically and under proper use with good condition belts.
Quite frankly I am bored of this subject and those who feel need to purposely shit on a product, company, and custom knife maker Ken Onion. Who developed a good product to help people sharpen knives. And deserves far more respect than he or Worksharp is receiving from some like yourself. All because some do not understand how to properly use the product or some non existent CATRA testing or he said she said gossip on the KOWS. I also repeat that once you sharpen your knife you can keep the edge with a steel or ceramic honing rod to eliminate over sharpening and increase the life of your knife. There is no reason to use a KOWS or hand stone sharpening every time your edge begins to dull.
Do as you wish and convert whoever you can. But I am firmly in the Ken Onion Worksharp camp and I am not being swayed without conclusive proof.
Nothing personal. But this will be my last post on this subject and OP's thread as I find it disrespectful to smear a proven company and product that has proven to be as good as hand sharpening by professionals. Reality is the KOWS is proven by thousands of reviews and customers who use this product and follow directions. And that alone is all the proof I need.
Done with this discussion. And I apologize to the OP for hijacking his thread and the long rant. I have spoken my peace entirely too much on this subject.
Thanks for sharing your views and thoughts. Even if I disagree. Wishing you and everyone here a good week ahead.
